Manual Transmission Noise Poll
Do you hear this noise?
  • Total voters
    475
Photofrank
Frank
Detroit
2022 Bronco Badlands
Yes, Built-in September of 2022, I started noticing the noise at 900 miles. I love this truck.
It's being serviced now with 2500 miles. There is a fix for the 5th and 6th gear synchronizers but I think a shortage of parts. I am going on 4 weeks without my Bronco and I truly miss driving it.:confused:
kodiakisland
Arkansas
4 weeks for what?
BigHoof
PA
Ram 2500
Exchanging parts with more of the same is not really a fix.
gtabert
Greg
Woodstock, IL
'18 gt350r / '65 f100 / '99 Silverado / '15 VW TDI
It's being serviced now with 2500 miles. There is a fix for the 5th and 6th gear synchronizes but I think a shortage of parts. I am going on 4 weeks without my Bronco and I truly miss driving it.:confused:
If mine develops the noise, this is the very reason I will not leave my Bronco at the dealer. To sit in their lot waiting for parts is insane. I'll drive it into the ground until they get the parts for it.
Morrisattack
Hagerstown
BRONCO AND BRONCO
I'M wondering if this only a 22 problem or 21 also.
Malicar
Malicar
Jessy
Prince George, British Columbia, Canada
2022 Bronco
I'm selfishly hoping that everyone, or at least most, will have your same mindset. Because I have a scheduled 7MT build. The more documented cases, the more quickly Ford is likely to take action to permanently resolve it.
Completely valid. I was considering to just keep driving. I will be bringing mine in so Ford is aware of the numbers. Essentially the same as creating this poll. We must know how many are truly effected.
Mattyfly42
Matt
2021 4 door 2.3L MT
Mines a 21. Noticed issue for awhile. Awaiting parts for the TSB. Not sure what im going to do if they get here. Sounds like id doesn't work. Cmon @Ford Motor Company you F'd up now take responsibility and fix it.
Photofrank
Frank
Detroit
It's fine, there was a lot of pressure to get these built. I waited 15 months for it. Ford will sort it out.
Apparently, it's just a rough weld on those friction plates. When it's cold there tight and rub. In my opinion, I would not wait to get it in and get it documented. Besides they give you a loaner.
JawnyBronco
DelMarPa
2023 Bronco 4dr
Yea, What Friction Plate Weld??? 🤨
sasquatchbronco1
Too many
I got ahead of the curve and sold my Bronco. Not for this reason entirely, but for a brand new car I'm paying $700 a month for, I don't want it to turn into a second job to take the car to the dealership and try fixes that may or may not work. The window rattle TSB barely resolved the issue. Figured I would cut the losses early.
That being said, I still like the Bronco and think it is a fun vehicle. My new plan is to look for an old Toyota 4x4 truck.
Photofrank
Frank
Detroit
Yes, the 5th and 6th Gear synchros, the truck should be fine once there replaced.
SPITmadFIRE
CA
There are multiple instances of the TSB work AND new transmissions not resolving the issue. What new information do you have that replacing the synchros fixes anything?
JawnyBronco
DelMarPa
2023 Bronco 4dr
Photofrank
Frank
Detroit
I guess I will respond once I get my truck back. If it happens again it's documented.
But come on, It's a machine that was rushed through production because all of us thought it was cool and ordered one.
Ford has a service bulletin out on this problem, I trust they will get it fixed.
