Manual Transmission Noise Poll
Do you hear this noise?
  • Total voters
    474
SPITmadFIRE
CA
So who's willing to compile all this data and see if there's hot zones, a la the 2.7 valves?
I think the difference here is as far as we can tell, the majority of 7MT owners hear the issue. I’d be surprised if there’s a couple week range of increased probability like the 2.7L valves had. But even so, do transmissions have Julian dates we can easily access?
Bmadda
Wisconsin USA
1990 Bronco eddie bauer
LH side of case near bellhousing, build date is #3
Ford Bronco Manual Transmission Noise Poll trans tag
EDIT: the book says LH side of case, but the tag is actually on the RH side
Tricky Dick
Dick
PNW
www.TD-Distributing.com
Maybe it is inevitable and we'll all get it in time. I notice the TSB only said 21-22 yet there's at least one 23 owner that chimed in already.
huey
kevin
Ontario & Kentucky
LH side of case near bellhousing, julian date is #3
will take a peek and see what my date is
curious if this is a smallish batch issue or widespread
Classic28
Brandon
Maryland
Nissan Titan
Passenger side near the shift cables
Ford Bronco Manual Transmission Noise Poll F9DDFD75-A4FA-4694-80B9-5E328E3F7D6A
Blown331
Ryan
Waterloo IL
79 Bronco
No noise on my 2022 with 10/22 Build. I payed extra close attention and can't hear anything.
Didn't Ford learn their lesson with the Mustang. They need to stick with Tremec.
Classic28
Brandon
Maryland
Nissan Titan
@Classic28 is correct, PASSENGER side near bellhousing...thats what I get for reading the book instead of looking at the vehicle. Here's mine
Your sticker and transmission being dirtier then mine tells me I need to get off the pavement. Haha
gwp
Greg
Winchester, Virginia
Harley Davidson FLTRUSE
12K miles. Incl. one 6K cross country trip and rock / trail idling. VA garage kept.
The GOOD news here is we don’t have brittle valves. The Ford planners wanted to spread the wealth so you can only get a bad trans or bad engine, but generally not both. The 2.3 automatic guys are probably just sweating it out waiting for their special gift.
Tricky Dick
Dick
PNW
Officially changed my vote. I just cold started and left the door open so I could hear well. Ambient temp 40F and it hasn't run in about 24 hours. There's a clear grinding/rumbling/scraping that goes away if I push in the clutch or move the shifter all the way to the right.
Currently at 8800 miles and I would say I first noticed something at about 8500.
