Manual Transmission in for replacement!
rtazz17
Connecticut
2022 Ford bronco big bend
Bummer. i'm taking my bronco back to the dealer tomorrow. Hopefully there isn't a recall in our future. :(
You should be hopeful its a recall and not ford denying a problem. Recall is best outcome,highly doubtful though
PatioDaddio78
PatioDaddio78
Kirkland, WA
Yukon XL
@Ford Motor Company
I dropped off my bronco yesterday for the second time to have the transmission looked at. Service tech said "Not sure that Ford will replace it again." WOW, quite the response! So I get a bronco with a crap transmission that gets replaced with another crap transmission, but because it was already replaced I get to keep it! I'm not going to hold my breath on this one.
TJ308
TJ
1990 Ford Mustang LX
Almost 11k on my badlands no issues, and she's pulled some weight
Ford Bronco Manual Transmission in for replacement! IMG_20220814_011955_596
PatioDaddio78
PatioDaddio78
Kirkland, WA
Yukon XL
Thank goodness you have a trailer that you can use when your transmission goes out...plus a chevy to get it to the dealer!
PatioDaddio78
PatioDaddio78
Kirkland, WA
Yukon XL
Picked my bronco up with no solution for the transmission this time. According to my dealer, Ford now says there is nothing wrong with the noise even though they replaced for the same issue last time. Thanks @Ford Motor Company this gives me ultimate confidence in your product..I'm hoping that it will make it to the 60k powertrain limit/warranty!
djp
djp
Idaho
'22 Badlands 4dr || '21 Bronco Sport BigBend
Someone sent me the TSB, here it is: 22-2371
I've been told service is:
It's a complete transmission disassembly to gain access and replace the 5th and 6th gear synchronizer rings.
Ford Bronco Manual Transmission in for replacement! 1671110471217
PatioDaddio78
PatioDaddio78
Kirkland, WA
Yukon XL
Thanks! I sent to my service guys at the dealer, we will see what comes back.
FloridaBurgBronco
Don
Middleburg, FL
'24 4Runner TRD, former '22 Bronco Badlands owner
It's made by Getrag, not FoMoCo.
True, but it would be nice if Ford stopped using Chinese junk for their transmissions. I'm taking mine in on Thursday. They said they need a day to diagnose and then will update me. I wonder if they'll be able to get parts in a "timely" manner?
babraunagel
Golden, Colorado
Toyota FJ Cruiser
Well, technically GETRAG is a German company and has operations across Europe, North America and Asia. They're partially owned by Ford.
The way the Bronco manual transmission repair process has worked for some is that the first appointment is scheduled (weeks or months out). Then, when that appointment arrives The problem is diagnosed. The dealership orders the parts which, naturally, are backordered and take months to show up. Once the parts show up and another appointment is booked, the transmission is dismantled and they find out additional parts are needed which, naturally, are also backordered.
At other dealerships, the additional parts are not ordered and the transmission is put back together. This results in the same issue reoccurring a few months down the road.
Soooo..... yeah. I made my first appointment at the local Ford dealership (the one recommended by Ford corporate) a couple months ago. That appointment is not until March 9th. In the meantime, the Bronco is sticking close to home. No off-road. No long distance trips. Lots of noise in the xmission, though!
FloridaBurgBronco
Don
Middleburg, FL
Right, I understand it is, but the punch in the gut when I pulled up to the dealership when I bought it was reading boldly addressed on the window sticker, "Engine: Made in USA👍, Transmission: Made in China😒", gave me a sinking feeling. And now 6 months into this thing, the noise, which I thought was different than what was originally described, but after reading more forums and whatnot, found out, it's likely the same issue. So 6500 miles and mostly certainly more off-roading than most Bronco owners, it sounds like I need to park it and get it checked out. Made the appt today for Thursday. They said they need it all day to diagnose. Hopefully parts won't take forever. We are headed to north GA in March and VA and TN in June, both trips will see some Bronco off road action if it's available. My hope is that a lot more issues with supply chain are getting worked out. Hopefully one of them is this issue of parts. I mean with my luck, it won't turn out that way, but at least we have two other vehicles to allow us to manage. Let me know how your situation fairs as things develop.
babraunagel
Golden, Colorado
Toyota FJ Cruiser
Keep me posted! Congrats on getting an appointment so quickly - hopefully your repair will go smoothly!
PatioDaddio78
PatioDaddio78
Kirkland, WA
Yukon XL
I'm surprised you are having issues in a warm climate, I thought it was just a temperature thing...below 40 deg. I asked my dealer to do the service a while back and they never replied. So grind away we go every morning when I start up. I'll address it again at my next service appointment. Yippie skippy!
GreenbeanBob
nj
2022 Black Diamond
I just got off the phone with my dealership. My Bronco has less than 4K miles on it. It needs a new manual transmission. I had it in for the third time for a leaking roof and told them I was hearing a grinding noise from what I thought was the front end. It turned out to be the transmission. The dealership told me the new transmission is on it's way and should be done by early next week. Fingers crossed....
EVH1994
Make sure it’s revision E. Anything before that will result in the same grinding noise. Hardly anyone has gotten the rev E transmission either, so it’s not proven to be perfect yet. See the thread below.
https://www.bronco6g.com/forum/thre...-scraping-noise-grinding-sound.33282/page-200
PatioDaddio78
PatioDaddio78
Kirkland, WA
Yukon XL
My buddy just had the same issue and was told the transmissions are on backorder, big surprise. My replacement is no good that I got way back when and I'm waiting to hear back from my dealer on a solution. No surprise they are not in a big hurry to respond.....hopefully @Ford Motor Company will have this figured out by the time my warrantee is up!
