Manual Functionality
Mhans31b
Charlotte NC
Mini Cooper Bronco reserved
Most modern manuals have something in place to prevent an accidental shift into reverse.
I wonder how the Bronco will handle this and will the crawler gear have the same protection?
Used2jeep
Massachuvian
2007 Crown Vic P71
I'm thinking that the pull up ring will be used for both.
Go_Galt
South Dakota
Subaru Forester 6MT
I remember seeing a video (It was one where journalists were doing ride-alongs on Ford's off road proving grounds I think), and it showed the driver in a manual car engaging the crawler gear. It definitely looked like he was using the reverse lockout (ring you pull) to engage it.
D Fresh
Doug
Jeep YJ, Ford Fiesta ST, Mazda CX-5
Should have a pull up collar under the knob to get over to R and C. The 6 spd in my FIST has it for R.
Anthraces
Andy
Stationed in Japan
Japanese car/SUV unfortunately
yeah I remember that in one of the ride along videos. Have to pull the ring up to engage
Straight 6
Brad
Ca
BMW
I've driven cars with reverse high and left and it's not a problem
Typically the spring and pressure needed to get over to reverse is strong enough that it's very clear what you're doing
The pull up ring is annoying and unnecessary
Used2jeep
Massachuvian
2007 Crown Vic P71
Typically either or.
Corsair
Jacob
San Francisco
Escape
Yeah, saw this exact question asked on FB an hour or so ago, someone showed a picture of it working how you describe.
MaverickMan
Shane
I miss my toploader 4 speed. Had one in a 78 Van and a 67 Cougar. My shifter arm had to have muscle and I loved it. Took enough work to shift into any gear that you knew where you were at all times.
Lifeliberty
Moonbeam👀
Columbus, OH
Makes me wonder who the fuck is the moron that makes this a necessary process. It all started with one person... You know who you are:cautious:
Get In The Bronco
Terry
Colorado Springs
19 F-150
I talked to one of the guys at the Bronco event and he confirmed that the pull up ring is for Reverse and the Crawl gear. Said you can go into the Crawl gear even at speed. Recommend under 10mph, but more testing was being done.
bfabpt
NoVA
'20 Rav4
It's a good safety feature. I have 2 past vehicles (Mini JCW & Wrangler JK) with close R and 1st gear (upper left) position, that i have accidentally shift into reverse. I was lucky not to hit anyone with unintentional backing. Recent Wrangler JLR that I had have this pull up ring as well, but i had to give up and trade for a Tacoma.
Used2jeep
Massachuvian
2007 Crown Vic P71
Either a pull up ring, a push down lever or an extra spring are all worth it.
Broncomputer
Los Angeles
GTI
I believe all the manuals I've had were push down to get into reverse.
When I search crawler gear, I only see Bronco coming up, is the Bronco the only manual made with a crawler gear? Like ever???
Also does anyone know the max and min speed for the crawler gear?
