Major soft top issue
bishop0577
Robb
Corvallis, OR.
2021 Bronco 4 door base/sqatch
Have you tried a carwash?? Inside gets wet!
I have taken mine through the car wash and have had no leaks. I have opened the top and even taken it completely off. After putting it back on, I still have no leaks going through a car was. Wonder if it's a mechanical issue with yours. Is this becoming a common issue?
Southern Girl
1974 Bronco/2024 Wildtrak
Hey all, Reluctantly i switched to a soft top, to take delivery quicker. Boy was that a mistake!
Opening to position 1, and now the top will not seal above the doors! I can stick my hand between the roof framing, and the top. (See pic)
My dealer has reached out to his superiors to hear that this is normal!? If true, this is unbelievable for 50k+. The wind noise is substantially greater than it was before ever opening.
Please report this if you are also having these issues, maybe
@Ford Motor Company
will do something to correct it.
Mine does not do that. It sits completely flat like it did the day I bought it. Full disclosure, I have never tried sticking my hands through the top, because why?
I haven't even flipped the top back on our Bronco yet as we just picked it up this past weekend. Drove home in 50-60mph wind gusts and the wind was definitely making it in through the top when we had crosswind gusts.
We have quite a lot of high winds in FL and I have never experienced this, thankfully.
JaxGtc
Mine is completely sealed. You couldn't put a penny in it let alone a finger or a hand. It sits flat and is a tight seal. Perhaps you bent something in the opening and closing process? Going on 10 weeks and no issues like what you are describing.
Frankie945
Frank
Louisville KY
Q50
Jeep jk has plastic rails that the top would tuck under. It was always a major pain to put the soft top on and needed strong fingers to grip the top and pull it under the lip. I always dreaded doing it because it was such a pain in the butt and the tabs would stretch out loose their form and not hold very well over time. The Bronco top has a completely different design I’m guessing because of the frameless windows it just droops over the roll bar to make it super easy and quick for anyone to open and close. I understand why it’s designed this way but the convenience has its drawbacks. I’m fine with it has a awesome heater I just hope in the summer it stays cool inside like it stays hot in the winter.
ramblinwreck
Georgia
`22 Wildtrak, '21 Wrangler Rubicon 4xe
I have had a Jeep JKU soft top(we have a JLU now, but the soft top is still in the basement in a box), so I was sort of expecting the Bronco design to be similar to a Wrangler. I guess I was mistaken.
I never really had any issue at all with the soft top of my JKU. It was mostly as quiet and held temps about as well as the hard top did. I was hoping the Bronco would be the same. I am more worried about excessive wind noise on the highway than I am about temperature though. Hopefully it doesn't sound terrible on the road.
Gamecock
I have the soft top, and it's really good on the highway as far as wind noise, and it's super easy up and down. I really like it. The OP was mostly freaking out over nothing....just some drama. Nothing to see here, most who have it so far love the soft top.
Cheshire
Steven
FL
4Dr Bronco BaseSquatch 2.7L
I've owned both Defender 90 and Wrangler soft tops. Since then, I've owned 3 Wrangler hard tops. I was done with soft tops long ago and never considered it for the Bronco. Unfortunately, this is a lesson you have to learn the hard way! We're quite happy with our Bronco MIC top.
Frankie945
Frank
Louisville KY
Q50
I don’t hear wind noise coming from any of the windows I hear it coming from the very back in trunk area. It’s not bad but you can hear it. Just reminds me of my jku. My main gripe of a soft top is you can hear everything outside. People talking, peoples radios and loud crappy car mufflers sitting at red lights. I use to jam my radio in my cars I don’t now because everyone can hear what I’m listening too.
