Lux Headliner Issues
Robbie_S
2022 Bronco OB Cactus Gray
We just picked up our Outer Banks Lux on Wednesday and have notice there is a few areas where the headliner is peeling off the top? We push it back down but it seems the adhesive just isn't sticky enough anymore. Has anyone had issues with their headliner peeling back at some edges? I'm gonna take it into the dealership to see if they can get it to restick with something but wanted to check and see if anyone had an easy fix or solution like 3M foam tape or something. Thanks in advance.
JeebusCripes
Mn
ā€˜94 M998, ā€˜89 Wrangler
Are you referring to the sound deadening? Or is there something else that has to do with LUX that I’m not understanding?
The sound deadening doesn’t have anything to do with LUX.
if it’s coming off can you use spray adhesive?
JBlanco
Julio
Charlotte NC
I think the sound deadening is the same for all hard tops regardless of the package ordered. OP, pics will help in determining the issue.
Robbie_S
Robbie_S
I thought the Lux package came with added sound deadening stuff. I guess I assumed this was that. I haven’t seen any other broncos to know, my bad. But here’s a pic. It just keeps popping back down, drives me crazy.
Ford Bronco Lux Headliner Issues BAEAE4C6-8279-4D81-9DB5-2DB8FF47FBEC
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
I'd take it back to the dealership and have them either:
  1. Fix it
  2. Remove it properly, and go buy/install some better quality sound deadening
talbot
Calgary
2dr BL AMB
yeah it's not the greatest quality liner thats for sure
some have had similar issues, but think it's been fine for most, myself included
take it back to the dealer, they can fix quickly
2020FordRaptor
Ty
Nevada
2020 Ford Raptor
I would take back to your dealer. It is under warranty and might as well use it. You shouldn't have to fix it yourself if it is under warranty.
Rayder
Brighton,MI
F-150
The "extra" sound deadening is all in the engine compartment. Doesn't do much for wind and road noise. Either way the headliner is mediocre at best, mine has a few loose spots too, but I'm just going to get an aftermarket one eventually so I haven't bothered with getting it warrantied.
ABorges
Art
Fresno CA
1973 F100
Mine is doing the same thing in that exact area, haven't took it in yet to get fixed
Murraydog11
Rick
2021 2Dr Outer Banks, Jeep Cherokee
I would make sure it's not moisture coming in through the seam.
Robbie_S
Robbie_S
It’s not moisture. We’ve only had the car a few days and gave it a car wash yesterday and there was no leaks or wet spots anywhere. Thanks for the feedback, I’ll make an appt with the dealership and let you all know how they handle it.
Five-O Donut Hole
Northern Illinois
2012 Ford Raptor-Loaded-Original Owner
Noticed today mine is also starting to do the same thing in the same spot
