Sound deadening Headliner
BroncoOB
Texas 2 California
Toyota Sequoia, Tesla
Les Korcala
Les
Florence, Montana
Xterra
It's discussed elsewhere on the forum, but the short answer is: No one knows absolutely for sure, but that terminology is typically used to mean sound deadening material / mat that is applied against the body structure under the carpet and trim, and that's what we're all assuming it means in this case.
There is actually proof that headliner or deadening won’t do much improvements
guy on You Tube showed by applying very good quality sound treatment under the black thin carpet 300$ worth of it and tons of labor and with sound level device he found 5-10% improvement ? Bronco hard top removable plastic roof are not quiet to many components , modular sections even driveling off road you can hear not only sound noise but rubbing sounds from different parts of the roof structure.
it’s not winning situation here !
ScottyC
Rome NY
2022 Bronco 4 door
When my 2022 showed up, I spec'ed it with a headliner and either the dealer or Ford "forgot" to install it. (My bet is, the dealer thought since it was no charge, it would be included automatically...wrong) So for a month and a half, I had my Bronco without the headliner. When the liner came in, I brought it in and was pleasantly surprised that it did indeed make it a little bit quieter and less "tinny" inside.
Les Korcala
Les
Florence, Montana
Xterra
They don’t works, it’s why you install good great audio system and enjoy it to kill the initial sounds leaking in to the Bronco
Ny the end of the day it’s off road rig. Steep sloping windshield will increase your frontal area while driving anyway way.
easy check with sound level device. I did this versus my Xterra with more relaxed windshield angle , huge differences.
23Bettie
Tony
Round Rock
Bronco Badlands
My 2023 was spec’d with the headliner, but arrived without it. The dealer told me Ford removed it as a free option, and that they would put one in for $800. I took all the way to the dealership GM and he will not respond to my messages. This is not my only issue with theses guys. Piece of crap dealership.
aniljavali
Anil
Plainfield, IL
www.youtube.com
Bronco Badlands '22 & Tesla 3
it is less useful than you think. I was in the same boat spent $500 to buy it from Ford and installed with Kilmat, I hardly notice any change in the wind noise. there are bigger openings in the roof and frameless doors are the cause for worst wind noise especial when it is crosswind.
am learning to live with it.
Hothead Headliners
Boise, Idaho USA
HotheadHeadliners.com
Jeep Wrangler & Jeep Gladiator
