Lower control arm skid plate
toughtoaster
Kansas City
2012 Mustang GT, 2022 Bronco Badlands
Mine rub at full lock on 33" tires with the +55 offset. The thud I kept hearing was when it hit the wheel weight.
Yeah after some investigation that’s what I determined mine to be as well. Seems I got a not very balanced batch of wheels because every single one has about 20+ grams of weights.
Nogame24
Denver
I believe this is the part number; W717969S440. They look correct. I've ordered a set and will update once I confirm.
Are you sayign the bolt on the bottom of the A arm is single use or is this on the upper control arm? I have mine I am about to put on but I want to avoid using a bolt over it thats not its intent.
fordbroncowildtrak2023
Phoenix, AZ
Silverado, Bronco
The nuts that attach to the strut on the lower control arm are listed as single use. The RCI lower control arm skid attaches to these bolts. Even though I bought replacements, I reused the nuts and added some Loctite.
Victorsen
Vic
Maryland
Ford bronco
I purchased the Rci A arm skid plates and they rub when I turn the wheel all the way. Have a stock badlands non sas. Is the dv8 or jcr ones better
Victorsen
Vic
Maryland
Ford bronco
Do yours happen to rub or contact at full lock? Mine might have in a parking lot today… need to investigate more
Did you figure out what the rub was with the Rci A arm skid when you turn the wheel full.
Victorsen
Vic
Maryland
Ford bronco
I had the same issue Rci an arm skid plate touching the wheel. I had to create a notch in the skid plate to prevent it.
Ford Bronco Lower control arm skid plate IMG_7938
LoneWolf1903
Caleb
Tennessee
2021 Ford Bronco Badlands
I did a test fitment of the RCI skids over the weekend on my HOSS 3.0 equipped Wildtrak. They will work just fine. I need to install my manual stabilizer bar disconnects (AC Fab Sasquatch Links) first because these skids cover the lower bolts.
I know this is a pretty old thread but have you had any issues since installing the skids on your Wildtrak with 3.0? I just installed some tonight and didn't seem to have any issues but notice that RCI mentions they're not compatible with 3.0.
Phoenix, AZ
Silverado, Bronco
Nope. No issues to date!
Combustion_King
Derek
MA
Yes
i have the DV8 ones, pretty straight for install, i have a SAS package, and i have a few good marks from rocks and what that would have def hit the arm itself, same for the rear shocks, totally worth it for me. I ride fire roads, north east trails with mud and granite.
RobWTX
I am, after having them on a few months. The skid hits the control arm a little. On the outer most edge (closest to the tire), there is hardly any clearance. I haven't hit anything or bent it, but now I am hearing a little clunking noise when I turn and am going over bumps. I think they updated their page after I had issues with the rear skids not fitting, they added the HOSS 3.0 that day as not compatible. They work just fine, but make some noise.
I'm looking at other options just in case. I don't want to wear a spot off the control arm if it rubs there.
LoneWolf1903
Caleb
Tennessee
Have you found a replacement yet?
RobWTX
Nope. And actually after looking at the part number for a lower control arm, same on all Broncos, HOSS does not seem to make a difference. Not sure what the next step is.
