Skid plate for rear lower trailing control arm
Second Nature Overland
Keith
North Texas, US
www.youtube.com
2023 Ford Bronco Badlands Sasquatch 4-door
Seems like Foutz is the only one that will fit.
Your other option might be to cut and grind those factory skids off, then, assuming the rest of the mount is the same as the non-Badlands part, you could install one of the non-Badlands aftermarket skids.
Victorsen
Victorsen
Vic
Maryland
Ford bronco
Sent a PM to them asking..
got back from response from Carli said it doesn’t fit not wide enough. Foutz is also confirming for sure as well.
IwannaGOfast
Jon
Brea, CA
2021 4 door Badlands, 1991 Ranger Long Travel, 2014 Cruze Commuter
Like stated before, the factory plate could be cut off with a grinder. The factory welds do not look that long so it wouldn't be that difficult.
I am looking at the carli skids myself and that is probably the route I will have to go on mine.
@AdamF@IAG will those skids be made in USA?
AdamF@IAG
Adam
Maryland
iagoffroad.com
'22 Bronco Raptor, '21 Bronco 2 and 4 door, '24 Ranger Raptor
Yes. They will be our IAG Offroad line which is made in Maryland/Pennsylvania, right along side of our popular EZ steps and new EZ guide door storage solution.
chtucker
Kirkland, WA
FJ Cruiser
Will they fit over the models that have factory skids?
Victorsen
Victorsen
Vic
Maryland
Ford bronco
I sent him the measurements of my badlands over to IAG so hopefully they should be able to confirm
Victorsen
Victorsen
Vic
Maryland
Ford bronco
If you are willing to grind then there are many options jcr, ASFIR, Rancho, ac-fab, Carli . I am looking for one to fit over the existing plate
AdamF@IAG
Adam
Maryland
iagoffroad.com
Yes, they do fit over the factory installed skids. Our designs are meant to be inclusive of the different trims wherever possible.
Victorsen
Victorsen
Vic
Maryland
Ford bronco
Yes they confirmed it will fit. I sent them the measurements.
AdamF@IAG
Adam
Maryland
iagoffroad.com
