Lower Control Arm Cam Alignment Pins
Elevator Man
Dan
2016 Mercedes GLE, 2021 Badlands
Anyone know of a replacement for the pins that the front lower control arm alignment cam bolts rest against? I've bent a few of mine. The pins are press fit into the frame and should be a replaceable item. Went to the dealership and the schematic isn't showing any part number or that they are even there. @flip
Ford Bronco Lower Control Arm Cam Alignment Pins 1678724741913
Ford Bronco Lower Control Arm Cam Alignment Pins 1678724762375
FYI, I was able to find some for a Chevy, but no idea if they'll fit.
Ford Bronco Lower Control Arm Cam Alignment Pins 1678726530162
V1Rotate
Brevard, NC
2022 Wildtrak
I don’t have a source for those or p/n but curious how you bent them? Drive it with the nut loose?
Elevator Man
Elevator Man
Dan
Doing some rock crawling in the mud with poor traction. The front end slipped off and dropped about 4 feet and bent them.
Silver-Bolt
Eureka, MT
I doubt they are available as a separate P/N. Looks like they are swaged in from the back side.
Elevator Man
Elevator Man
Dan
I've been able to remove the old ones easily, they are just a press fit. I did find some online for a Chevy, but no idea if they will work.
Ford Bronco Lower Control Arm Cam Alignment Pins 1678726475858
Elevator Man
Elevator Man
Dan
I have an alternative if I can't end up finding find the pins. I'm going to copy what Rough Country does for their higher lift kits and just weld a flat bar on in place of the pins.
Ford Bronco Lower Control Arm Cam Alignment Pins 1678727405675
flip
Phil
IN
www.ruxerparts.com
Fords
I saw Moog offers these but wasn't able to find looking up by year, make or model. May just have to punch one out and take some measurements.
Tricky Dick
Dick
PNW
www.TD-Distributing.com
Elevator Man
Elevator Man
Dan
Elevator Man
Elevator Man
Dan
Elevator Man
Elevator Man
Dan
oh ok, I removed one and seems to be made out of aluminum
I got an alignment and the person said they sell replacements at Napa Auto Parts, but I havn't verified.
The stock ones are incredibly weak. Mine bent.
Wildtrak'n
Will
Riverside CA
22 Bronco
I ordered 2 different types from Amazon I will report back with info on if they worked
