Loctite or Anti-seize for Sasquatch rings?
broncosor
2022 Bronco Badlands
I am having my beauty rings powder coated.
I am a noob with that kind of things please educate me:
- there is yellow loctite on the screws, should I remove it and if yes what kind of product?
- I got both blue loctite and anti seize at Home Depot. Which should I use? I have seen in a different thread that we should use anti seize. That means no loctite at all? Is there not a risk for them to come loose with vibrations?
Thanks
Nolabel
Van
Mesa Az
Thanks
Depending on the wheel and hardware would determine using some anti seize or nothing at all. I'd personally use just the smallest amount of anti seize myself on aluminum.
Raptor.Tremor.Bronco
Miami, FL
2021 Bronco Wildtrak, 2014 Raptor, 2020 Tremor
I've been using antiseize for my Raptor for many years. I don't remember the wheels having thread locker from the factory back then. I don't see a reason for it. Antiseize has definitely been a lifesaver
dcaero
Bronco OBX SAS
Removed my bad advice.
Blaven
Pennsylvania
I didn't use anything when I reinstalled. And I don't think you'd want red lock loctite on there unless you never want to take them off again.
gtx_bronc
GTX
stainless steel bolts into aluminum = always use anti seize
if you dont you risk galling and having to extract them. Put them in slow - dont use power tools or the speed creates heat and can cause galling also.
Roger123
Roger
VA Beach, VA
Anti-seize only, please do not use red Loctite, the bolt heads are made of cheezium.
Dom
Dom
Phoenix AZ
2000 Ford Expedition, 2013 Ford Fusion
I recently had my rings powder coated as well. I started to remove the yellow loctite and grew tiresome of it so stopped. When reinstalling I found that the ones that had a lot of leftover yellow loctite were difficult to install. I would say pick away the ones with a hefty amount and then use a drop of red loctite when installing. If it feels too hard to torque down, pick away some more of the yellow loctite and try again.
With that said, removing all the yellow and using a drop of red is the correct way to go.
Is this one of those "let's see him do it, and see how it goes" posts? LOL.
gtx_bronc
GTX
seriously - OP read this Bolt Depot - About Thread Galling
cigartexan
Jack
Boerne, Texas
1964 F100 SS - 2012 F-350 SD - 2021 4D Bronco FE
NO!!!!! Red loctite requires heat to break loose. Blue is what should be used if anything. The yellow is factory applied loctite and would have been fine. Loctite Red or Pink will bind too strong to the aluminum and could damage if not properly heated. Be careful taking those off!
dcaero
Bronco OBX SAS
Fair. Bad advice. Learned something new today.
broncosor
broncosor
So from the article anti seize will prevent galling which is good but what about the screws coming undone with the vibrations? It seems that adding a lubricant to a screw will make it unscrew easier
Canā€™t we apply both blue loctite and anti seize?
Oldhippie
Barry
Santa Cruz, Calif.
BMW X1, ā€˜1928 model A, ā€œ23 Bronco
I would not worry about them loosing, they really have no stress on them...use anti-seize! And torque correctly.
Lifeliberty
MoonbeamšŸ‘€
Columbus, OH
Tension keeps the screws in. Use proper torque
"Canā€™t we apply both blue loctite and anti seize?"
You CAN, but don't do that. And probably never admit to anyone you asked that question
Gtrekker
Gary
NJ
Abs
[/QUOT
Absolutely...Do not use Red loctite, you will strip the bolts trying to remove... Blue should be the strongest I would suggest.
