Mind sending the circut file to me?Did mine with reflective vinyl and my daughter's cricut. It's not perfect and the reflective vinyl doesn't cut thru easily, so weeding it is a pain in the ass. Each letter has to be placed separately and then use a heat gun to lock in place - which isn't ideal with reflective either. Still toying with the idea of just doing it with epoxy I'll have to mix up some colors first and see what I like best. I like the idea of the reflective - maybe can add some reflective dust on top of the epoxy once it's starting to tack up.
Just finished mine using Cricut, not perfect either but pretty close and honestly close enough as with my traction boards mounted, no one is ever going to see itDid mine with reflective vinyl and my daughter's cricut. It's not perfect and the reflective vinyl doesn't cut thru easily, so weeding it is a pain in the ass. Each letter has to be placed separately and then use a heat gun to lock in place - which isn't ideal with reflective either. Still toying with the idea of just doing it with epoxy I'll have to mix up some colors first and see what I like best. I like the idea of the reflective - maybe can add some reflective dust on top of the epoxy once it's starting to tack up.
Looks good! There is a traction board mount? Who makes it?Just finished mine using Cricut, not perfect either but pretty close and honestly close enough as with my traction boards mounted, no one is ever going to see it.
There may be others but Pura Vida Off-road is what I have.Looks good! There is a traction board mount? Who makes it?
Want to share that CriCut file??Just finished mine using Cricut, not perfect either but pretty close and honestly close enough as with my traction boards mounted, no one is ever going to see it.
It is notIs the 'Ford Performance' lettering available anywhere?
thanks
The Ford Performance lettering on the rear hoop. Post #52I give up - what am I looking at?
