Limb Risers Install
mikeeshim
Los Angeles, CA
MBZ E350, supposed daily driver
I've pretty much been done with most of the mods that I wanted to do, and decided it was time to share my latest addition.
Living in SoCal, not sure how much need I'll have for them but it just looked too cool and I really wanted them.
So I present to you:
Ford Bronco Limb Risers Install PhotoGrid_Plus_1655432201616
Ford Bronco Limb Risers Install PhotoGrid_Plus_1655432100796
Ford Bronco Limb Risers Install PhotoGrid_Plus_1655432015911
Ford Bronco Limb Risers Install PhotoGrid_Plus_1655432301429
The limb riser kit came from Gearshade.
The main feature of this kit is the quick release pin on the front.
Due to the LED light bar on the roof, I was not able to use the supplied roof mounts, so I drilled 1/4" holes to the front side of my light bar mounts.
I also had the Trailrax trail sight accessory mounts on the front, but after consideration, thought that the quick release was a better option.
My last upgrade is the Trailmax TRMR roof rack, which will open up a whole new world of upgrades, at which point I'll post more updates then!
SuzH
Susan
Burlington, WA
www.crittear.com
BMW X5
Thats one sizzling bronco! Well done!
I just installed the limb risers. We put them to the test yesterday. They sure helped on the tight PNW trails. Sadly, the accessory caps don’t fit on tight after adding the top plate, and they are now missing. 🥺🤬
Engineer fail!
i, too, had the flat mount on the trail site. Not sure what to do for a flag mount now.
what is that you have on your front bumper?
mikeeshim
mikeeshim
Los Angeles, CA
Engineer fail!
Thx @SuzH !
I now have 2 locations for a dune flag now.
The one you see in the image is the Swarfworks flag mount.
I'm using the mount with this quick release mount and flag.
Ford Bronco Limb Risers Install KakaoTalk_20220620_065338813
I also have a mount on the back, where the tailgate reinforcement kit from Hammerbuilt is installed.
You'd need to get the entire kit with the accessory rail and the antenna mount for this to work, so it's a lot more money, but also a lot more functional.
You can see the little metal stud above the gas can; the flag clips on there.
Using this mount for this flag.
Ford Bronco Limb Risers Install PhotoGrid_Plus_1663597669230
Yes, sometimes I use both flags because... why not? :D
Let me know if you need any other suggestions.
SuzH
Susan
Burlington, WA
www.crittear.com
BMW X5
Thx @SuzH !
I really like that accessory mount from Hammerbuilt. I’ve worried about the tire weight on the tailgate. It’s a good in between to use u til I get a new bumper system where the tire weight is on the bumper.
I really like your rig. You’ve done some great mods.
Tell me about your light bar, please. Wired to a switch?
mikeeshim
mikeeshim
Los Angeles, CA
Thx again!
The Hammerbuilt is definitely a good option for the tailgate. I was deciding between this and the RTR one, but in the end chose the Hammerbuilt because of the modularity, whereas the RTR seems like it only works with other RTR accessories.
For the lighting, I have two light bars, a 40" on the roof and a 30" on the bumper with this mount.
I also have 6 fog lights, 2 ditch lights, chase lights, and rock lights.
Ford Bronco Limb Risers Install PhotoGrid_Plus_1663172619401
Due to this, the factory AUX switches and wiring did not supply enough power so I ended up taking that out and getting a SwitchPros with a SDHQ mount.
Ford Bronco Limb Risers Install PhotoGrid_Plus_1654973777025
The lights are a bit overkill but they help so much on night trails.
Headlights/Fogs only:
Ford Bronco Limb Risers Install Headlight only
With the lIght bars on in the exact same spot:
Ford Bronco Limb Risers Install All lights
The bumper light bar puts out enough light, but because it's so low, it tends to cast a lot of shadow behind every little bump, so the roof light bar mitigates that problem.
Here is the bumper light only (in a different location):
Ford Bronco Limb Risers Install 30 inch only
Hope that helps.
  • Like
Reactions: abe
MJBbase22
M
Alfa Romeo Sider, VW GTI
Sweet look with the fender delete!
mikeeshim
mikeeshim
Los Angeles, CA
After installing the @TrailRax TRMR rack, I had to come up with a different method of mounting my limb risers to the roof. The mounting point was much higher and further back, and the current length was too short. Spoke to the team at Trailrax and figured out the best place to mount, and also had a talk with @GearShade and they were gracious enough to extend the limb risers to whatever length I needed, which was 5". Extremely grateful for that. This was above and beyond anything I was expecting.
I found the supplied roof mounting brackets from Gearshade and installed them upside down on one of the slats of the roof rack, and it turned out like this:
Ford Bronco Limb Risers Install 20220926_183652
A closeup:
Ford Bronco Limb Risers Install 20220926_183701
Anchor point:
Ford Bronco Limb Risers Install 20220926_183707
The mount:
Ford Bronco Limb Risers Install 20220926_183714
And finally, a glam shot:
Ford Bronco Limb Risers Install 20220926_190346
My pics are terrible and the rig is dirty, but overall, I'm extremely pleased with how everything turned out.
A big thanks to Trailrax for their sound advise and Gearshade for all of their help.
Both of these are great products and highly recommended!
Roc_Cero8
Carlos
Springfield, VA
2022 Ford Bronco Wildtrak
A closeup:
Anchor point:
The mount:
Hey Michael,
I actually have the same roof rack. I like your setup. Did you need to do any additional modifications to make this work? I kinda want to copy what you did here. Did you have to make a special order with Gearshade for the additional 5"? What about the mounting bracket to the roof rack, did you have to modify anything?
Your bronco looks bad ass :)
mikeeshim
mikeeshim
Los Angeles, CA
Hey Michael,
The team at Gearshade was gracious enough to send me longer cables, so I just sent in the ones that were sent initially back and they sent me the long ones.
The mounts were not modified, I just flipped them upside down to make them work. The most ideal solution would have been to be able to open the hood with the limb risers on, but overall, I'm happy with the setup.
Roc_Cero8
Carlos
Springfield, VA
Hey Michael,
Thanks for the reply. You wouldn't happen to remember what the measurement of the cable was? I will probably order soon.
Thanks again,
Carlos
mikeeshim
mikeeshim
Los Angeles, CA
Hey Michael,
Thanks again,
Carlos
I can't remember, it's been a few years now.
However, my post says it was extended 5" longer, not sure how much that helps. Sorry.
Nvm, I had them in the back so I just measured them.
Heading out to Joshua Tree in a few hours so I found them in the back while checking gear.
Looks like the "inside measurement" of the cable is 52".
The crimps and the locks should all be standard, so that's the measurement you'll need to provide.
Ford Bronco Limb Risers Install 20250227_112159
Ford Bronco Limb Risers Install 20250227_112154
Here's an updated truck pic, it is now matte and very heavy!
Ford Bronco Limb Risers Install 20250227_112304
Roc_Cero8
Carlos
Springfield, VA
Thanks again! Enjoy Joshua Tree. I am on the east coast in VA. I am probably going to take my Bronco out to Shenandoah/George Washington National Forest this weekend :)
CalvinT
Calvin
Phoenix, AZ
With the limb risers relocated to your rack, can you open the hood without releasing the limb risers?
Gluestick
Josh
Nashville
instagram.com
No. Mine will still contact limb risers. They would have to be mounted wider for the interference to be mitigated.
