Light Bar for RC High Winch Mount
BLINDSIDE
Melbourne Florida
4D Bronco First Edition
Has anyone tried to install the 20” light bar after installing the Rough Country high winch mount? What is the trick?!?!?!?
Ford Bronco Light Bar for RC High Winch Mount IMG_1145
RagnarKon
Ford Bronco, Escape, Focus
You mount it from the rear.
Which means you'll have to take the mount off the Bronco—although you may be able to squeeze it in there with the winch off.
BLINDSIDE
BLINDSIDE
Melbourne Florida
Great! 🤣. Was hoping someone figured out a way to finagle it up in there. Thank you
BLINDSIDE
BLINDSIDE
Melbourne Florida
Got it done, not an easy task:
Ford Bronco Light Bar for RC High Winch Mount IMG_1158
Had to remove mount connection bolts and flip 2 of the bolts under the winch around so the light at would fit in the intended location.
Ford Bronco Light Bar for RC High Winch Mount IMG_1156
Ford Bronco Light Bar for RC High Winch Mount IMG_1157
MPTB
Pat
Wisconsin
Good luck with that rc winch. Mine quit after the second use.
