Lobber
Ray
Kansas
Did you have any rattle with the sub firing against the enclosure?
Well you were right ended up being way too much rattle even firing towards the seats so I moved it inside the enclosure on the side wall and that took care of the issue.
Ford Bronco Kicker Key Amp 200.4 Install DIY Video - Do this first! D9CC9770-F1E9-451E-9929-56FFF12BF9D7
22BlackDiamondGreen
Shawn
Louisville, KY
2013 Ford 150 1955 Ford F100
Well you were right ended up being way too much rattle even firing towards the seats so I moved it inside the enclosure on the side wall inside the enclosure and that took care of the issue.
Where did you get your straps …… I haven’t received my pluginplay or sub yet so not sure what comes with it
mikey_photo
Allentown, PA
2021 2dr Badlands
I posted this in another thread as well but, figured it really belongs in this one.
As I previously posted, I purchased "kit 14" and I'm super impressed with the plugnplay kit.
This kit comes with the harness, 200.4 and also an AudioControl LC2i. I installed the 200.4 in the same location as the OP and that worked out great.
Speaker upgrades:
(4) Kicker KS (with 300 hz bass blockers on the fronts)
(2) Sony XS-GS1621's in the kick panels
I decided to mount my LC2i in the glove box and just purchased the KICKER 500.1 which will live in the same place. I'll be finishing off my system next weekend with the amp install. It actually fits perfectly in the bottom of the glove box and it will be velcroed in place. I did drill a few holes in the back of the glove box (added some rubber grommets) for the wiring.
I like this because it keeps everything pretty much self contained to one area. Outside of running speaker wire to the rear (for the sub) all of the wire runs are nice and easy. I also like that I can lock the glove box for that little bit of extra perceived security.
I know it's not for everyone... but my glove box is generally just filled with junk and this is much better usage of the space (for me).
Ford Bronco Kicker Key Amp 200.4 Install DIY Video - Do this first! AMP-SETUP
As for the sub, I ended up going with the KICKER 48TRTP122 for the rear of my 2dr. While it does take up a lot of floor space, it doesn't really take up a ton of cubic space. I like this box because you can stack items on top of it, if necessary.
Ford Bronco Kicker Key Amp 200.4 Install DIY Video - Do this first! IMG_1400
I'll post some updates once I have the 500.1 installed next weekend.
VVSidewinderVv
Tim
Pittsburgh, PA
20 GMC Sierra
Didn't think you'd really need the LC2i since the Key 500.1 has DSP built in. No?
SoCalG
SoCalG
Southern CA
2022 2DR Bronco BD
With the Plug N Play kit and the 200.4 Kicker amp install, do you need to run a separate power cable to the battery or does it pull power from the harness\head unit?
Bronc OH
Columbus, OH
1974 Bronco Explorer
You do not need to run separate power for the Key200.4. It draws from the power from your factory harness.
kbBronco
Kyle
Carrollton, TX
2021 Ford Bronco, 2019 Honda Rebel 300
Kit 11-4 work for tying more power to my front 4” and back JBL speakers while prepping for a sub?
ldog77
Len
Maryland
2021 Ford Bronco OBX; 2018 Chrysler Pacifica
Noob question here: I purchased Kit 16. Do I need to run a power cable from the powered sub to the battery, or does it draw power from the harness that's attached to the Kicker Key and the back to the head unit?
Lobber
Ray
Kansas
You need to run a power cable and the power cable comes in the kit.
plugnplaykits
Ct
All powered subs must have power connected to the battery and grounded
Brock9281
Atlanta
I'm running Hertz dcx100.3 in the dash and Polk DB402 in the rear. The Hertz up front are notably better than stock, but as i mentioned, the stock head unit starts clipping so badly at even moderate volume levels it's still not great.
And everything sounds like crap in the rear IMHO regardless of what drivers are used and what Forscan tweaks are made... But improved drivers like the Polks are a little less crappy.
How do you like the Hertz?
RainbowStix
A Big Island
Toyota Tacoma
What should the volume on the stereo head unit be at during pink noise?
TheShark
And don't try to play the pink noise through your phone, I found out the hard way.
22BlackDiamondGreen
Shawn
Louisville, KY
How did you do the pink noise
