Jmschultz22
Joel
Detroit, Michigan
2017 Chevrolet Impala, 2017 Ford Explorer,
Does the pushing against the covers hinder the performance in any way? Im a total rookie with sound stuff but this setup seems great after doing a little research
I have not had any issues with performance, just tight fit!
BadK22
TN
'21 Bronco '92 Jeep YJ
TripleB
Georgia
2021 Ford Bronco Base Sas 2.7L, 2026 Ram RHO
Installed.
Kit 16 with Kicker Key 200.4 and LC2i Pro
Sub later
1 pair Kicker CSC65
2 pair Kicker CSC4
300htz on front 4”
Super easy and major improvement over stock.
mikec426
Russellville, AR
22 4dr Sqtch, '04 Yam FZ1, 22 Versys 1k, 19 Ninja
Installed.
Sub later
1 pair Kicker CSC65
2 pair Kicker CSC4
300htz on front 4”
I’m doing a sub later as well. Got kit 17 on the way.
Speakers waiting to go in:
Kicker 46CSC674
Kicker 47KSC404
And Rockford Fosgate R14X2
No bass blockers though… think they’re really necessary?
KeithK
Keith
Ford Bronco
Installed.
Sub later
1 pair Kicker CSC65
2 pair Kicker CSC4
300htz on front 4”
Awesome. Did you need the LC? I’m debating it or just the Kicker amp alone. Thanks.
Mike5681
Ohio
More Door Sasquatch
I don't see anyone installing waterproof speakers, does everyone think that's unnecessary?
TripleB
Georgia
Kicker 46CSC674
Kicker 47KSC404
Not really sure but with the front 4 speakers being on the same channel and different sizes it makes sense. It sounds great, so good it needs a sub to finish it off.
TripleB
Georgia
All of the wiring harnesses are different so if you want a sub later order accordingly. I called the supplier, he recommended kit 16.
Teewsda
Aaron
Georgia
I installed kit 19 key 200.4 with a 10" hideaway sub.( before price hike and sold out)
Wow. Huge difference with just the key and stock speakers. The sub pulls it together nicely.
Might upgrade the speakers and might not. Sound stage is hugely improved with auto setup on the key.
Not sure where to mount the sub so I have a long pig tale in plastic loom so I can move it around for now.
Will have to wait for highway and top off to decide if I need to tweek more but very happy with the results and ease of install.
Shout out to plug and play for the phone time and help sorting out an install question.
mikey_photo
Allentown, PA
2021 2dr Badlands
I installed my "kit 14" today and it makes a huge difference. I am so pleased with the outcome and totally worth it. This kit includes the harness, Kicker Key 200.4 and the LC2i.
The install was relatively painless and took me about an hour.
In the next couple weeks, I'll finish it off by adding the Key 500.1 to the LC2i, and a down-firing 12" sub in the rear.
I previously switched out all of the factory speakers (which made a difference) but the amplification and DSP made them come alive. I hate saying "night and day difference" but it really is.
I'm currently running:
Kicker KS 4" in the dash (with 300 hz bass blockers) and rear pods (no bass blockers), and Sony XS-GS1621's in the kick panels.
TripleB
Georgia
The plan is to wait for a JL stealth box but I’m not sure I can wait that long.
mcinfantry
Lee
Louisiana
Badlands 2 door
jh3113
Jake
Phoenix
Subaru Outback
If you are using the Kicker KEY, you dont necessarily need the bass blockers as the amp will set the crossover points for you. You just need to ensure the DIP switches are in the correct positions for your particular setup.
Good to know! I installed the bass blockers before i installed the AMP, so when I go to calibrate the Key, I will see how removing them sounds.
Scotteasymoney
2015 F150. 72 maverick grabber
Installing the blockers on the dash will be a big help on keeping the 4" from sounding muffled. The lower 120htz setting will work better on the larger kick panel speakers. Just my opinion. When I installed my Rockford Fosgate 4" in the dash they sure did move alot with just the factory base power. Have the 300htz blockers to install and hopefully order the double key set-up Monday when they start taking orders again.
