Kicker Key 200.4 reset issue - 2023 Bronco
johns2te
Tyler
Richmond, VA
2023 Ford Bronco
I did a speaker upgrade following @RagnarKon's fantastic guide and youtube videos earlier this summer. I installed a new sub with a dedicated amp and I installed new pod speakers, front dash speakers, and floor panel speakers all run off a dedicated kicker key 200.4 amp installed under my steering wheel.
Unfortunately as of recent the Kicker 200.4 key auto settings from my mic keep resetting. It seems to be a result of auto software upgrades? Certainly when the battery disconnects it resets the kicker.
I just want my calibration and settings for the kicker key 200.4 amp to save and stay saved in the bronco without having to go pull the panel drop the amp down plug in the mic and recalibrate every week. What is going wrong here?
where_are_the_AC_seats
Andy
New Orleans, Louisiana
I followed @RagnarKon 's advice and videos, too. How did you know that your amp's configuration kept resetting? Was it just that you could hear the difference? Or did it give you error beeps?
GreenbeanBob
nj
2022 Black Diamond
Did you figure out the problem?
I'm having a similar problem.
I installed the key200.4. It is powered directly to the battery (the m5 accessory stud).
If the truck has been off for more than a few minutes, the amp turns off the autotune settings when I restart the trunk.
Pushing the button on the mic wire enables the settings again...
I contacted crutchfield (I bought the amp from them). They sent me a replacement amp.
The new amp is doing the same thing...
23OBX2.7
AB Canada
2023 Bronco
O had nothing but issues with 200.4 sold the warranty replacement and got better one Audison 8.9....which also sums high level signals, as well a low level....cost a lot more though.
