Jerry can mount solution to tailgate?
CatcusGrey
Ryan
Seattle
Ford Fusion hybrid
Hey All
Going Overlanding near Tahoe in about a month. Looking for a solution to store extra fuel and water jerry cans to the tailgate. Most of the options I'm seeing out there are several hundred dollars or universal types that I am not sure will fit well. Any recommendations? Pic for reference.
Ford Bronco Jerry can mount solution to tailgate? Screenshot 2023-08-12 071507
Turn Offroad
Cole
2021 First Edition
Hey All
We are close to releasing a Jerry Can mount for our TC3-M1 tire carrier reinforcement If you’re also looking to beef up your spare tire assembly.
https://turnoffroad.com/collections...bronco-hd-tire-carrier-tailgate-reinforcement
Destination Bigfoot Bronc
Jamie
Richmond, Virginia
2019 F150 Limited, 2022 Bronco OBX Cyber Sasquatch
Hey All
Here's what I came up with
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
broncorik
Cheapest way to go is RTR spacers for OEM hinges, RTR plate, and carrier of choice. RTR carrier is nice but $$$$$ and heavy. You can save a LOT of weight by using Scepter can and this carrier:
https://atoverland.com/products/at-can-holder-scepter
they weigh about 6 pounds and carrier is about 5...versus 3x that for Jerry/RTR carrier.
5 pounds of gas is 30 pounds, Jerry can is 15ish, plate is probably 5 with spacers...RTR carrier is 13...that puts you well over the max tailgate limit with even a stock wheel/tire combo. You should also get a M2M tailgate limiter with whatever combo you get so you don't smash your tail light.
Jamie
Richmond, Virginia
Not if he uses a tailgate reinforcement like mine clearly states that I used. Also not bolting them to the hinges and using the molle panel allows you to move the mount closer to the tire which will allow you tons more room having a 35" tire. Which will in fact give you even more clearance when opening the tailgate.
broncorik
Got it...but add up the weight of your M2M tailgate reinforcement, the molle panel, the RTR carrier, the Jerry can, and 5 gallons of gas...you are over the Ford weight limit for the tailgate (especially with a 37). The tailgate reinforcement may offset some that, but despite the strength of the reinforcement all that weight is transferred to the pillar...and I can assure you that it flexes (and you have to compensate for latch adjustment). That also stresses the hard top (if you have one). I was merely trying to point out weight...and even with your setup, swapping a Scepter can and the aluminum carrier shaves off almost 20 pounds. Another option is the 15 pound reinforcement plate from Hammer built and using their angle bracket and a Rotopax or simply bolting the Jerry can carrier to that bracket. I wouldn't be chiming in if I hadn't already wasted a lot of time and money trying the BAMF system, the RTR system, the RC system, and the HB system. I now run a swing out carrier...because even with the lightest possible setup I noticed flexing (and that was with Raptor hinges). Just my 2 cents...I hope whatever anybody chooses to use works out great for them. Note however, with any plate system, unless the holes through which the bolts pass to the hinge are countersunk there is still the potential for some movement. With the Raptor hinges, the bolt holes are separate from the through holes which attach the hinge to the tailgate. Also, with the RTR spacers, you could easily use OEM hinges and unbolt only one at a time so as not to have to risk having a nut plates fall into the chasm of the tailgate.
Scott R Nelson
Meridian, ID
Not sure if you have the OEM rack. If you do add this HF cargo basket and as many 1-2 gallon plastic gas cans you think you’ll need ratchet or bungee strapped down? Remove rack when not in use.
https://www.harborfreight.com/150-lb-capacity-roof-mounted-steel-cargo-carrier-64101.html
Thanks for that link. The rack looks like it would work well on a stock Bronco roof rack. I was thinking that I want to haul a couple of 5-gallon Jerry Cans when I go way off road. I know that the metal ones from Harbor Freight would hold up, not so sure about the plastic ones.
The last time I drove to Jarbidge Nevada, I was thinking that extra gas would have helped, since gas there is $8.00 per gallon and the next nearest location with gas is 60 miles away. Of course, paying fifty bucks to put in enough gas to get back out is still way less than buying the extra capacity to haul along with me. Next time I'll be sure to top up at the last chance before heading out there in the middle of nowhere again.
broncorik
Scepter cans are tougher than Jerry cans...they are what the military uses. They have fallen off various military vehicles at speed and sustained nothing more than scuffs. They are rough to get in places like CA, and they are expensive, but if you ask anyone who has owned/used them and Jerry cans generally the Scepters get rave reviews. The big weight savings alone make a difference.
Scott R Nelson
Meridian, ID
Thanks for the pointer. I can get one at the local Tractor Supply for quite a bit less than a metal can from Harbor Freight.
I'm getting closer to actually going out and buying all this stuff. ;)
broncorik
If you go that route make sure to get the correct spout (they have a unique vent system for a fast pour) and a wrench to get the cap off (they can get tight with pressure changes). Also, they are slightly different interventions that the Jerry can so if you get a carrier it needs to be Sceptor-specific. There are companies that make dual Scepter carriers and singles.
Scott R Nelson
Meridian, ID
...if you get a carrier it needs to be Sceptor-specific...
Ummm.... I was planning to use a couple of ratchet straps on the above mentioned Harbor Freight cargo basket. Should work the same regardless of the type of gas can. ;)
tock13
Tony
WA State
Mazda, 66 Honda CT90, ‘94 Toyota Xtra cab
Hey All
What bumper is that in the picture. I was looking for a double swingout. Tire is a bit too high but hopefully it’s adjustable.
retiredarmymp
Steven
Whitehouse, Texas
2021 Bronco Badlands Sasquatch
I used the Hammerbuilt tailgate reinforcement with the RotoPax mount, the JCR Off-Road spare tire basket (I built the support brackets myself out of aluminum because they are made of steel and too heavy, in my opinion, from JCR; Hooke Road half luggage rack and Front Runner boxes. We just completed a week long trip to Silverton Colorado and everything worked great!
Ford Bronco Jerry can mount solution to tailgate? CL9
