Jeebus, tires are expensive.
judah3497
bryn
Santa Clara, California
bronco 2021
Wow, just wow. Out of curiosity I looked up a set of tires for the bronco. BFG K02 are $2250! In line with the other top contenders. Good grief, I had no freaken idea tires were going to set me back 2 racks! Hopefully I don’t need them for 2 more years.
I've had 3 tires replaced, and a set of glass, and yes, that's an exorbitant price. You enjoy it when you're driving the car for a spin, and you feel suffocated whenever a part needs to be replaced, which is a huge number.
zjc26138
Zach
Steubenville, Ohio
2021 Bronco Sport BB
Worth while to note C-rated tires are better for on/off-roading comfort as well. The have a little more "softness" than E-rated tries. (That said, E-rated tires are a little more robust and resistant to pinch flats, so there is some trade-offs.)
So which load should I go with? I would say I only go offroad a couple of times a month. Most of my driving is paved or gravel roads. And when I do go off road its generally just through big mud holes. I'm thinking I'd be fine with C rated.
Discount Tire
Arizona, USA
discountti.re
All Things FORD
We typically only recommend going up to an E rated for 2 reasons:
1: If you are towing near the vehicles maximum on a regular basis the heavier tire construction will run cooler and would likely last longer so jumping to the E rated would be a benefit.
2: If you are regularly traversing sharp obstacles or are off-road on a regular basis, the E rated tire construction can add some peace of mind when off-roading.
zjc26138
Zach
Steubenville, Ohio
Cool, thanks for the response!
89PACHANGA
Jon
Hampton Roads, Virginia
Mercedes CLS, LR Defnder 110, BMW M4, Bronco 2DRBL
Awaiting delivery of my 2 Dr. BL with LT285/70/17 AT Tires, I am taking all off and going with another brand. I believe these are BFG's on truck.
If interested in 5 tires will sell for half of your quoted 2250.00 plus shipping, I am in Coastal Virginia.
RagnarKon
Bryan
New England
Ford Bronco, Escape, Focus
Heh... what @Discount Tire said. (I was going to say effectively the same thing.)
You can also look for D-rated tires... which is kind of the "in-between" tire but those are relatively rare these days.
broncobase1
Lincoln
22 Bronco Base
Big tires big bucks that is how it goes, and one reason I'm happy with the base tires and 16" rims. I use my Bronco as a daily driver and not into rock crawling, so the base tires are great. I may upgrade to a more aggressive AT tire, there are plenty of options with the 16" rims.
Raptor911
Raptor911
Broadlands, VA
I just picked up 5 KO2s (315/70/17) from FB market place for $1250. Only 1100 miles from a jeep 392 with the extreme recon package
ERock62
SoCal
2017 F250
I need to buy 37's for my F250 in my AV.
Holding off as long as I can because I will be doing 2.5" Carli suspension also. Rip $$$$$
Jon_chimpo
Jon_chimpo
Sacramento, CA
22 Wildtrak
That’s bad ass! I may re-join FB marketplace for that deal.
