Interior fuse box location
SPITmadFIRE
CA
I’ve removed the glove box compartment, looking for the interior fuse box to wire up my dashcam/radar detector, and for the life of me can’t figure out where the fuse box is… is it behind one of the trim panels, and if so, does anyone have a decent picture of where to look? Everything I can see says “remove glovebox” and nothing else
not sure if it’s different based on trim, but:
- 4dr
- Badlands
- Lux
- Marine grade vinyl
RagnarKon
Ford Bronco, Escape, Focus
It's directly below the glove box behind a trim piece that protects it from being kicked by the passenger.
Manual wrong, ignore me.
SPITmadFIRE
SPITmadFIRE
CA
It's directly below the glove box behind a trim piece.
below the glove box as in, under the passenger footwell? Or directly behind the glove box? I saw what looked like a plastic cover for changing out the cabin air filter, is that the trim piece? Or is it more towards the door/speaker?
Hkak45
K
Illinois
21 Bronco Black Diamond
No it is not. It is under the steering wheel. That cover just folds down and it's above the OBDII port
Vico
Chicago, IL
The interior fuse box is located above and to the front of the DRIVER side kick panel. You have to pull down the plastic trim under the steering wheel to access.
zombie
New Brunswick, Canada
This is false. The manual states that's where it is, but it is on the driver side behind the headlamp control switch.
Ford Bronco Interior fuse box location 20211229_201005
Just pull back slightly on the edge of that panel and it should swing down as in the image.
RagnarKon
Wow... that's where my gut told me it was based on where it is on the Ranger and where I thought I had seen it on my neighbor's Bronco... but I went to verify online and in the manual and both of those sources said it was beyond the trim piece on the passenger side, so I just assumed I was wrong.
Sorry @SPITmadFIRE, did mean to send you on a wild goose chase, I just assumed I was wrong.
SPITmadFIRE
SPITmadFIRE
CA
No worries! I’d never seen it on the drivers side in any car I’ve worked on so totally fair to recommend the manual’s location 😅
SPITmadFIRE
SPITmadFIRE
CA
That’s hilarious — never seen it tucked away there, let alone with wrong instructions in the manual. Really makes you worry about service appointments in the future 👀
thanks!
Hkak45
K
Illinois
I went looking for that dang thing for a while when I installed my camera since the manual states it's on passenger side. Even under the steering wheel there is nothing to indicate that a fuse box is behind it like some vehicles have so you just have to pop off the whole panel to reveal it. Makes me wonder what else is incorrect in the owners manual though. Never in my life have I had an owners manual be incorrect.
SPITmadFIRE
SPITmadFIRE
CA
Alright, dashcam is all wired up — used an add-a-fuse on slot 2, which is used by the power windows. Grounded the add-a-fuse circuit to the silver 8mm bolt and washer near the supports that the trim panel clips into. The darker, 7mm bolt above it did not make a decent connection to ground.
Weirdly enough, I tried using fuse slot 3 which is wired to the wireless charger and side mirrors circuit — but those aren’t switched?! They’re not even when the car is completely off. Didn’t realize that, now I’m worried I could kill my battery leaving my phone on the charger 😂
BigBlue7
New Jersey
‘23 Black Diamond Sasquatch
Where the heck is fuse #12 for the climate control?? My box has 11 and 13 but no 12
Mikeinmidland
Midland, tx
Which fuse is it?
22 Spyder
Fort Lauderdale
2024 Azure Bronco Raptor (DD),2022 Porsche 718 Spyder(weekend)
Wiring a Wolfbox G900 Pro tonight. Will use fuse #2 with the windows.
