interior dome light solution for dark soft tops - pics
bbkat
LA
2014 Toyota Tacoma
Wife has been bugging for a dome light. Thank you!
Ksjrb03
Tx
F250
When I get my aftermarket hardtop sometime around 2032, I’m def doing something like this.
Your solution using the cross bars in the softtop is great. The ultimate is to use the dome lights to power the extra lighting, I refuse to use an upfitter switch for this. Not an easy fix but I’m working on it!
Itchysquatch
Luke
Vermont
99 4runner, 2014 E class
there is got to be a way to trigger a light off of zone lighting or something... I should have mine next month and will look into further.
Ksjrb03
Tx
F250
Yes, the way is to use a PWM converter module like the after market tail light modules for a 4 pin. I have the module and used it to verify this will work. The tail light module is huge and will not fit under the panel, plus it’s over kill for this being it’s setup for 3 light circuits.
Lonestar777
Great content! I was all worked up to try and wire something into an upfitter switch or something, and then the other day I ran across this battery powered magnetic LED light at Home Depot. I bought it and it works so well I may never hard wire in anything different. The body panels of the Bronco are non-metallic but the roll bar works great. A bonus is that I can attach this to the tailgate table I installed for working on things there in the dark.
https://www.amazon.com/dp/B07NM4X978
Ford Bronco interior dome light solution for dark soft tops - pics 516ebJnzDJL._AC_SL1000_
pharden
Paul
Newport, RI
2019 Ford Edge ST
I picked up one of these lights for my Bronco too. BTW my wife has an Audi Q7 and the interior lighting is fantastic. It has lights eveywhere!
DrSquatch
Russell
NE
'22 Explorer ST
That a real rolly there, mate?
DrSquatch
Russell
NE
'22 Explorer ST
tjnoffy
Jay
Maryland
'21 Bronco OBX Sas, '22 Escape Hybrid, 2 Harleys
You can still operate the soft top lift fine. It does not interfere or come off.
Great job! So does this mean folding the soft top all the way back with rear windows removed, or just folding back the front section?
Wanted33
Down south in Dixie
My goodness I do love good old American ingenuity. (y)
Headsong
Perfect. I have one over my desk that's rechargeable via USB....but don't know how well that would hold in the cold. Of course, AAA's won't either.
Jason hamilton
Jason
Knoxville TN
Tahoe
Beat me to it. All broncos are a dark cave regardless of top.
I’ve rigged up a couple different options for interior lighting around the roll bars and it works great. Unfortunately the dome lights are PWM and cannot be tapped to work from. Attention lighting vendors, million $ opportunity.
This is some cheap LED tape lights. My second product worked even better but I didn’t get a pic.
great use of one of the aux switches
doccoch
doccoch
Doug
Midland, Texas
2019 Mustang Bullitt, 1967 Mustang Fastback
That's so crazy. That was my first idea. The LED light I posted above and originally intended to do in this fashion HAS a magnetic strip on its back already. My bars have NO magnetic attraction at all. So no iron, nickel, or cobalt. I assumed they were made of aluminum? I tried other magnets on it too and there is no attraction.
doccoch
doccoch
Doug
Midland, Texas
honestly, I just folded the front part all the way back and STARTED folding the back part back. I did not go ALL the way back with rear windows removed. But I really can't imagine it would matter how it is attached.
