interior dome light solution for dark soft tops - pics
doccoch
Doug
Midland, Texas
2019 Mustang Bullitt, 1967 Mustang Fastback
The interior of my Badlands is SO dark. I've come to the conclusion that those with soft tops just don't have good inside lighting. I thought about rigging up LED striping but this looks decent and is an easy fix.
Ford Bronco interior dome light solution for dark soft tops - pics IMG_5007
Ford Bronco interior dome light solution for dark soft tops - pics IMG_5011
Bought these cheap roll bar lights: https://www.amazon.com/dp/B07WFZ6DB4?psc=1&ref=ppx_yo2_dt_b_product_details
and these higher quality 1" tube/rod boat clips: https://www.amazon.com/dp/B07G8437CQ?psc=1&ref=ppx_yo2_dt_b_product_details
Drilled out some extra holes in the back of the clips and then secured them flat to the back of the LED light via zip ties.
Ford Bronco interior dome light solution for dark soft tops - pics IMG_5005
Ford Bronco interior dome light solution for dark soft tops - pics IMG_5006
Ford Bronco interior dome light solution for dark soft tops - pics IMG_5008
Then just snap it on to the soft top cross bars.
***EDIT: the crossbars are NOT perfectly cylindrical in cross section. They are oval. If you feel, they are kind of flattened (wider than they are tall). So you have to come at it from the side and push from the side and then turn in to place. Same when you take them off.
The soft top is attached to the bar permanently on the superior side (which is why me must use a C-type snap clamp and can't go completely circumferentially). You have 3 options where to put them. I chose all three: over the front seats, over the back seats, and over the trunk area. All are perfect. You can still operate the soft top lift fine. It does not interfere or come off.
These are pics with my garage completely dark (you can see I have a little dusk-dawn LED plugged into the back seat floorboard that gives off a blue ambient light at night to match the front footwell. Gonna paint it black cuz it bugs me:
Ford Bronco interior dome light solution for dark soft tops - pics IMG_5014
Ford Bronco interior dome light solution for dark soft tops - pics IMG_5015
Headsong
Can you easily access the batteries?
swami37
Fort Lauderdale Florida
1950 Ford F-1 and 2020 F150 FX4
Nice find. They look good
2Jeeps&PatriotX1
Denver, CO
Assume you need to manually turn them on/off?
UtahBrandon
Brandon
www.puravidaoffroad.com
a number of classics and my 4dr Badlands
MIC top lighting really isn't any better.
Ksjrb03
Tx
F250
Beat me to it. All broncos are a dark cave regardless of top.
I’ve rigged up a couple different options for interior lighting around the roll bars and it works great. Unfortunately the dome lights are PWM and cannot be tapped to work from. Attention lighting vendors, million $ opportunity.
This is some cheap LED tape lights. My second product worked even better but I didn’t get a pic.
Ford Bronco interior dome light solution for dark soft tops - pics BBD69FE2-8633-48AD-AF3B-81396EA78690
UtahBrandon
Brandon
That is sick pimpin!
Ares
Fox
Atlanta
you could still trigger them off a relay though, or is that what you did?
doccoch
doccoch
Doug
Midland, Texas
When I get my aftermarket hardtop sometime around 2032, I’m def doing something like this.
Ksjrb03
Tx
F250
Nope. The “trigger” wire in the dome light is a PWM signal which is a constant 11v. It will force the relay to always on.
