Installing tow hitch. Rear bumper torque specs?
Drew5150
Drew
1975 International Scout 2
Insallling tow hitch: is thier torque specs for rear bumper? Please and thank you
710-oil-614
Cal
Columbus, Ohio
2023 Maverick Tremor, 2010 Toyota Tacoma
Does the rear bumper need to come off? Don't have my bronco yet but every other hitch I've put on I've never removed the bumper.
Drew5150
Drew5150
Drew
Have to remove because of the way the bolts are installed
Ford Bronco Installing tow hitch.  Rear bumper torque specs? 16297477589245409975116706631742
Thed
Ben
Raleigh, NC
'22 GX460 '16 Miata '67 F-100 '21 Streetfighter V4
Ugga duggas!
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Thank @flip for this:
501-19 Bumpers2021 Bronco
Removal and InstallationProcedure revision date: 04/29/2021
Rear Bumper
Removal
NOTE: Removal steps in this procedure may contain installation details.
  1. Raise the vehicle on a hoist.
    Refer to: Jacking and Lifting (100-02 Jacking and Lifting, Description and Operation).
Vehicles With: Rear Fog Lamps/Rear Parking Aid
  1. Disconnect the rear bumper wiring harness connector.
Ford Bronco Installing tow hitch.  Rear bumper torque specs? video
Ford Bronco Installing tow hitch.  Rear bumper torque specs? Hel
All vehicles
  1. On both sides.
    Remove the bolt.
    Torque: 20 lb.ft (27 Nm)
  1. NOTE: This step requires the aid of another technician.
    Remove the bolts and the rear bumper.
    Torque: 59 lb.ft (80 Nm)
Installation
All vehicles
  1. To install, reverse the removal procedure.
710-oil-614
Cal
Columbus, Ohio
Oh wow - you sure do. Always have used Draw-tite hitches and all of the bolts come with wires on them that you use to thread the bolts through the frame and hitch - not sure that would work in this application though.
GL. Take pics!
Drew5150
Drew5150
Drew
Rear Bumper
Removal
All vehicles
  1. On both sides.
    Remove the bolt.
Installation
All vehicles
Thank you
Exomodo
Ryan
Marquette, MI
Ranger
Maybe one of the dealer guys can answer, are those recovery loops a part that cross references to other vehicles? They look familiar, like I might have some from an F150... not the strongest design, but at least they are mounted to the frame rail. The thin-ish sheet metal the loop is welded to is a failure point if the pull is off-axis to the frame rail, but you're pretty stuck in a ravine if you bust one off...
Blech, that hitch looks worthless and weak [/Dee Schneider voice], a near exact copy of where and how the Jeep Wrangler hitch mounts. I'm looking at the Ranger hitches tonight to see how they mount...
devhodge
Devin
Chi-Town
Honda Fit
You don’t need to with the Curt hitch…110 ft-lbs. ~$120 from Realtruck.com
Ford Bronco Installing tow hitch.  Rear bumper torque specs? D78776E1-E5F7-4461-BBC6-D31F0F941EB9
JHawk
Ray
Heartland, USA
Fusion Sport
Leave the bumper on and put the bolts in from the other side with the nut on right side of your picture.
FourHorses
Four Ford Horses and an Expedition
Nuts appear welded on.
Blksn955.o
Greg
Wentzville, MO
Ugga duggas!
4-5 of them to be safe. This is of course after running them down as far as you can with a wrench.
Exomodo
Ryan
Marquette, MI
Ranger
I have no words. A bit myopic in the design
It's designed to be assembled quickly with minimal thought or automated with a robotic bolt driver. Zero consideration for repair or maintenance. Dollars waiting on dimes...
