mpeugeot
It mounts with 3M tape. Get it from the factory and use either fishing line or dental floss to remove it and mount to somewhere else. It's battery powered cr 2032. Not my picture and I have no clue as to why all the paper clips. 😂
Like @Rick Astley said they had/have a bad batch of these. Some have been lucky to get the newest ones and have been working great while others are dying within a week. The way things are going with the Bronco I wouldn't put much faith in getting a good batch.
You can lock the fob inside and use the keypad to get in. Also the app is dependent on having a good cell signal which isn't always the case when you're hiking or camping in remote areas.
If you have a hitch some are using these.
https://www.amazon.com/HitchSafe-HS...ler+hitch+receiver+safe&qid=1628704178&sr=8-3
Just saying...
CARdiac
Joel
Maryland
Hummer H3 Alpha, MINI Cooper S JCW, TVR 280i
B Spence
Bruce
Oklahoma
2010 Ford Raptor SVT 6.2L
So I did not order the key pad - I don't like the look on the car and had them on my Flex but never used them. but this would be ok. did you order the pad separately from the Car order?
Manda13
Amanda
Corsicana Texas
Nissan Rogue
Does anyone know how hard it is to remove the one installed from the factory and move it elsewhere? I'm not looking to destroy my paint but by the time I found out it could be located elsewhere my bronco already had a vin and I couldn't remove it.
Boxer4
TRUCK
I know a few people have said that the fuel door doesn't lock when the car is locked is this confirmed?
I can't even scrub the side of my civic when washing it without the fuel door popping open if the car is unlocked, this would be a PITA on an off road vehicle especially with the cap less system.
I thought it did as well
Confirmed-it does Not lock on my BaseSasquatch.
timhood
Tim
Several
Only 1 way to find out. Do it and report back. Looks like a good location but I worry gas fumes will degrade the plastic.
The filler cap is sealed (EPA regulation), so there are no fumes during normal use. During fill-up, hopefully you live in a state that has vapor recovery systems installed on your fuel pumps (unburned fuel vapors are a significant cause of air pollution), but even if you don't, you're outside and the vapors would not remain in contact with the buttons.
TL;DR: non-issue.
grtharris
Grant
Skiatook, OK
Outer Banks 4dr, 2008 Mustang GT CS (Wife's), MH
Plan on mounting my on the B pillar. Does anyone know if each number pad can be rotated 90 degs?
timhood
Tim
Several
Putting an electrical device in an enclosed space with gas fumes. What could possibly go wrong?:oops:
You mean like how electric fuel pumps are mounted inside the gas tank? :)
No fumes inside the fuel filler door. The cap is sealed. If the seal fails, you'll get a check engine light and if you live in a state with emissions testing, it will fail. That said, even if there were fumes, we're talking about 3v DC battery power at milliamps level, and only when in use. Solid state electronics in a waterproof housing. No spark happening here.
wetdog
Bruno
pacific coast
2019 jl
i have the realtor lock box bolted under my tundra inside that is my extra key fob in a plastic bag simple use it every day ,usually lock keys in truck .
kellyweiss
Mr. Kelly
Excellent idea; I also believe "push-button" vs "spinning wheel" combination numbers would be more secure. Any ideas on what brand - was looking at this one:
Ford Bronco Installing Keyless Entry Pad in the fuel door 1628744941465
wetdog
Bruno
pacific coast
2019 jl
Just like that drilled some holes in back and bolted it down,every now and then a squirt of oil.
CJay
Chad
WI
'08 Ranger FX4 (MANUAL) & '74 VW Thing
Any chance that fits on the back side of the rear view mirror arm?
I'm guessing it's probably too long to fit the arm, or potentially too thick interferes with the glass when the door is open.
  • Like
Reactions: Dom
Dom
Dom
Phoenix AZ
2000 Ford Expedition, 2013 Ford Fusion
I was wondering the same thing. The B pillar would be a good location, but the sideways numbers would annoy me. LOL.
I would also totally mount mine on the inside of the filler cap. Or someone else suggested the side view mirror post. I wonder if it would fit there.
calgecko
Sacramento, CA
www.instagram.com
2021 Chevy ZR2 Bison V6
am I the only one who doesn't think it's a good idea to install an electronic device so close to the fuel filler neck?
