Installed KC Apollo Pros today!
Guardian1fox2
Jacob
Louisiana
2022 Bronco Black Diamond, 1923 Model T Racer
Incredibly simple using Bronco upfitter switches!
You literally cut off half of the wiring harness, and you don’t use the relay. Simply tie the 2 red positives together to the preferred aux switch wire by firewall; and attached ground to the point right next to it. So fast and easy! No fighting getting things through firewall is amazing.
Had some wire cover laying around and covered the wires behind the lights with it and it turned out great!
Ford Bronco Installed KC Apollo Pros today! ADD53D73-C1DF-4A05-B05A-18A9F05BB82A
Ford Bronco Installed KC Apollo Pros today! 612B6084-9CFC-44D5-AF5B-F4513748BFED
Ford Bronco Installed KC Apollo Pros today! BEBB3954-86F0-4625-9C42-3CFBD2D6A455
Part of harness and parts I didn’t use above ^
RickDeckard
Kentucky
Awesome. Love the look and they’re great lights.
5280Bronco
Denver
Love the old school look and I've wanted to run them, but I only find them in white. I want amber. Does anyone know if I can just swap out the bulbs?
F OR D
BD Green Machine
eww i like em. post a pic of the whole vehicle!
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
Guardian1fox2
Guardian1fox2
Jacob
Louisiana
It’s like a yellowish light already not like the white of headlights. But I’m sure you could just swap bulbs.
F OR D
BD Green Machine
Yes! Talk me out of the Ford Performance Rigids and into this!!
2020FordRaptor
Ty
Nevada
2020 Ford Raptor
Looks good!
Guardian1fox2
Guardian1fox2
Jacob
Louisiana
Well done. I just installed the 5” Kc Apollo Pros too. I’ve never done anything like it before, so took me a long time to make sure I was not doing something wrong by cutting off all the extra wires/relays. I got it working and used some electrical tape (like you did, to cover the red wires on the pillar). I also ran the wire under the cowel, which was super easy. My only issue is that the connector harness next to each light is exposed (above the pillar) because the wire length doesn’t allow it to hide under the pillar. — did you have that issue?
I used black plastic wire cover that you can get at auto parts store to cover the wires from cowl to lights. The passenger side plug went under the cowl, but driver didn’t, but the plastic cover covered the plug that was exposed.
Guardian1fox2
Guardian1fox2
Jacob
Louisiana
Thanks, I’ll get some of that instead to cover it. This what it looks like currently.
Also, did yours come with that Mount? , Mine had a different one which blocks the antenna.
You gotta use the mount to mount the light to the accessory points. Looks like you got just the light mounted to the point. I actually have a brand new set of KC light mounts for the bronco they sent me another set after USPS lost my first order, and they appeared one day in my mailbox. They’re like $75 but just pay for shipping and they’re yours. Comes with instructions as well.
Guardian1fox2
Guardian1fox2
Jacob
Louisiana
I’m interested. But how did yours mount to that bracket with a single bolt from the bottom? Mine is built on a hinge, so the bolt goes sideways to secure it.
*Maybe yours is the 6”, and designed different than my 5”
It’s the same. You have the hinge, and that bottom L shaped piece with the large bolt. That will bolt to the bracket, and then you remove both of the accessory screws and mount bracket there and replace screws. It raises the lights and puts them to the side so not in the way of antenna etc.
Guardian1fox2
Guardian1fox2
Jacob
Louisiana
look closely at these pics. You can see the same part that’s on your light mounted to bracket.
Ford Bronco Installed KC Apollo Pros today! BF23A320-E3B8-4AC7-8AEC-FB692F23B3B9
Ford Bronco Installed KC Apollo Pros today! 255466B2-B193-4C71-999D-668AB1B36DB1
rtazz17
Connecticut
2022 Ford bronco big bend
Nice! I put rigid ones on last night. Simple and straightforward
