Install soft top on Raptor
Bschurr
NY
@Brian_B & @HeliPilot I'm starting to think we've got different soft tops... I contacted Bestop (maker of the Ford OEM soft top) and they responded that their's doesn't fit the Ford Bronco Raptor specifically because of the center crossbar.
The soft top I bought from my local ford dealer is Trektop for Bronco 4-door (part 56873). Are you guys using a different soft top?
You are correct - you have a different top & I have no experience with the BesTop so my info/ details don’t pertain to your inquiries.
FYI - BesTop makes a soft tip specific to the G6 Bronco however, the OEM top is the Ford produced & supplied version.
YellaHEL940
Brandon
Indianapolis
2023 VelociRaptor
I think I am just going to go with the Broadict 2/3 soft top but have found new in box OEM soft tops on marketplace cheaper. So know you have me thinking.
RedTailHawk
RedTailHawk
2024 Ford Bronco Raptor
You are correct - you have a different top & I have no experience with the BesTop so my info/ details do need t pertain to your inquiries.
which soft top do you have? does it just fold back from front to back seat or does it retract all the way to the rear cargo area?
HeliPilot
Kenny
CT
2022 2.7L SAS
The Ford top retracts all the way down to the tailgate. It’s the one in my photos previously posted. I thought maybe you had the Ford Supplied BestTop when you were talking about rails. The Factory top only has 4 brackets. 2 on top and 2 in the cargo area.
Bschurr
NY
I have the full Ford factory, OEM soft top - just like @HeliPilot
Ford Bronco Install soft top on Raptor IMG_7613
Bschurr
NY
The soft top is the easy part - the supplemental brackets & parts were a bit challenging to acquire but with some perseverance, you will prevail!
Bschurr
NY
Do you know the part number for that top?
I believe it’s this —> M2DZ-7853000-BG
But, please do your own research to confirm.
vrtical
Doug AI
GSMNP, TN
Fords
I remove none of the hardware when I swap back to my hardtop. Though, I do adjust my front (windshield) latch plates when I swap, as the alignment pins from each top hit in slightly different places. I’m sure I could adjust that out somewhere else, but those two latch plates are the easiest to access.
thats good info, I keep wanting to go to a dual top setup, just haven't yet.
JLC64UK
J
KY
24 Bronco Raptor, 23 Ford Expedition Timberline
Yes you can swap them. Bought a OEM soft top from a gal who ordered dual tops and didn't want it.
Brought it home on the pallet and installed it about 6 weeks ago. When the weather turns colder in the fall will take it off and put the hard top back on. Got it hanging in the garage for the moment.
Ford Bronco Install soft top on Raptor E540EA85-007F-46DD-9C60-8F92B858B6B2
Ford Bronco Install soft top on Raptor 544D9DF5-E0AA-4D5C-A663-1F349CF5E136_1_201_a
EB66
1966 Bronco, 1964 F100, 2023 BRaptor
I have the bestop and just remove the cross bar in summer. You can modify it to work with a minor cut but I like the full open feeling.
Ford Bronco Install soft top on Raptor IMG_4426
freezey00
Anthony
Bronco Raptor
@JLC64UK do you happen to have a parts list?
