Install hard top over Bronco Cargo Bed Side Covers?
Sylvestermax
Tampa Florida
2023 Ford Bronco Wildtrack, 2015 F150 King Ranch
I took the hard top off for the first time today. I had purchased the Cargo Bed Side Covers a while back to cover the cargo bed sides while the top is off. Can I leave them in place when I put the hard to back on? or will they screw of the alignment of the rear glass and front roof sections? Thanks for any input.
Ford Bronco Install hard top over Bronco Cargo Bed Side Covers? 61XnCFnUJlL._AC_SL1500_
The Compensator
Cleigh
Wichita, ks
1994 bronco, 2015 yukon denali xl, minivan
I use them under mine. No issues that I can see. I did have to punch holes for the hardtop guide pins. The covers I bought didn't have the holes for them.
Ford Bronco Install hard top over Bronco Cargo Bed Side Covers? 20240901_125457
Saltwater Junkie
Sir Fishin
Tar Bay,Va.
99 7.3 F350, 22 7.3 F350,25 2.7 BADLANDS SAS
Ours have been on for close to a year with no issues.The covers seemed to actually help quiet down the interior noise.
Ford Bronco Install hard top over Bronco Cargo Bed Side Covers? 20240922_162244
smithjones6365
Jones Smith
1842 Red Bud, Tampa, FL
BMW
Yeah, you can usually leave the cargo bed side covers on when reinstalling the hard top, but it depends on the thickness and fit. If they’re pretty flush and don’t push up against the seals or rear glass, you should be fine. Just double-check alignment when you put the top back — if the rear glass or panels seem off, might need to pull them off.
JWBroncoATL
Atlanta
Toyota Tundra
Looks great! Which side covers did you buy and did the have a hole for the guide pin?
WheresMyBronco
Los Angeles
2023 Badlands
I actually wanted to buy a set to help seal and leaks in that area
Does anyone have a pic of how they look with the hardtop installed?
VirginiaHeritage
Frank
‘25 Bronco HE
I didn’t know this was a thing. What does it look like top-off without those covers? Haven’t taken my shell off yet.
EDIT: Is this irrelevant if I only have a factory hardtop?
Saltwater Junkie
Sir Fishin
Tar Bay,Va.
Sylvestermax
Sylvestermax
Tampa Florida
Thank you for all the input everyone. I have the Mabett covers. I guess I can go ahead and stick them on permanently.
Saltwater Junkie
Sir Fishin
Tar Bay,Va.
@Brad Fx I don't recall seeing that exact advertisement for the soft top only and not for the hard top,but it was probably there and I didn't pay attention. Regardless, the protection panels worked so great quieting the top that I took them off and am gonna put them on our new Bronco. I'd buy them again in a second.
J-Lugster
Ancaster, Ontario
2024 Ford Bronco Wildtrak 4Dr Oxford White
Hey Guys for those of you who have these protectors.....if you leave them on when you put back your hardtop does it raise the hardtop at all so it sits a hair higher than the middle hardtop panel?
I just want to ensure I am not impacting the seal between the rear hardtop piece and the middle one.
