Icon coilovers creaking/squeking
Horton
Cody
Tulsa
2022 bronco
Has anyone figured out a fix for this? Icon Customer service blows as we all know.
you can hear this bronco coming a mile away, it absolutely sounds horrible. It appears to be the rear coilovers. They creak so loud I’m about to trash these turds. Kings don’t seem to have this issue when I check out other broncos.
GToddC5
Todd
South Jersey
www.bronco6g.com
Do they use poly bushings? There's special grease for poly, and if you don't use it they will squeak, no matter what brand.
Brostango
Bay Area, CA
2005 F150 Crew, 2016 ATS Coupe
Oh no! How many miles do you have on them. I have about 1000 miles on mine and are super quite. If you have the reservoirs, check to see if the hoses are not rubbing against anything.
Horton
Cody
Tulsa
2022 bronco
I don’t believe they have poly.
they’ve done this since day one it’s not the hose. Gotta love icon customer service.
2500 miles on them
Bronco_joe
joe
Niagara Falls. NY
Did you retorque every bolt touched? Make sure everything is tight
JustSendItDude
Dustin
DFW, TX
2022 Ford Bronco
I had this issue with my internal reservoir setup. Took some poly grease and greased the shaft just outside where it enters the cylinder. Squeaks immediately went away.
Horton
Cody
Tulsa
2022 bronco
i will try this in an hour! Thanks
Murfman
Colorado Springs
2021 WildTrak, Cyber Orange soft top
No mine is just pure squeaking and creaking. That sounds horrible lol
I know. 2 dealerships and no answers. Have even emailed Bilstein to see if they have any recommendations. Was told that Ford designed the shocks, Bilstein just builds them. It is a Ford issue.
JustSendItDude
Dustin
DFW, TX
2022 Ford Bronco
Does it sound more like this?
Horton
Cody
Tulsa
2022 bronco
Update: Icon emailed me back after 6 weeks and said i should hear no noise, so they are sending me new front and rear coilovers. Pleased with that, but dang its a lot of work. Lol
choppersean
Sean
Arvada, CO
'22 Badlands Sasquatch, 2-door, EG, 2.7, Auto
Not sure what exact components went into your upgrades. About 3 years ago I replaced my front coil-overs and my rear leaf springs and Bilsein shocks all around on my Nissan Xterra. They all had natural rubber bushings and the thing squeaks to this day ......... mainly in the rear. Rubber is supposed to be "self lubricating" so they said not to put any grease on them. If you had polyurethane /synthetic bushings, my understanding is they are supposed to get grease. Wonder if that would quiet things down?
JustSendItDude
Dustin
DFW, TX
2022 Ford Bronco
My squeaks are back on my coilovers, unfortunately. At first, it was the rears, now, the fronts are back to squeaking again. Therefore, the grease seemed to only work for a few weeks. I am unsure if I did not apply enough or if there is more than a bad bushing going on with the setup. ICON wants me to send the whole set back in, but I'm hesitant as I won't have anything to use in the meantime.
