IAG vs Mabett Interior Lights
StrainedCMOS
Vancouver, BC
2023 Ford Bronco
Any consensus on which interior light kit is superior (IAG vs Mabett)?
IAG - Connects via taps to wiring in the front of the vehicle
Mabett - Connects via adaptor to rear dome light
For the most part the installation is the same in terms of light mounting, but it looks like IAG is a little harder to install given the taps required for installation.
Mabett however seems to have some QC issues with the lights failing or coming on delayed or won't shut off. Anyone out there that has had either the IAG or Mabett lights installed for a while wanting to weigh in?
Ninjak
Miami
I do not know anyone who has the IAG lights. As for the Mabbets, I have the "next version" of their lights and have not had any issues.
I do belive though that the Mabbets are the easier install, and so far, work as they should.
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
I personally wouldn’t want the lights to come on every time I opened the doors. They are very bright white. I only use them as needed with an AUX switch if I need to see something. The upgraded center dome light made a significant difference alone. So, IAG for me.
swami37
Fort Lauderdale Florida
1950 Ford F-1 and 2020 F150 FX4
Both from china
EinHoden
AR
GMC Sierra
I have the Mabett lights. Install was simple and they worked great for about 2 months, now they don't shut off without shining a light on the dash sensor. Haven't really had time to research or troubleshoot, so I just unplugged them from the dome light for now. May end up putting them on a aux swicth or just trashing them.
rpaluch1
Rudy
Tecumseh Mi
Ford Bronco
I have the same issue with the Mabett lights. I bought mine when they first came out. Now they have an upgraded light but in my opinion Mabett needs to make it right for their customers. This wasn’t an inexpensive purchase. Mabett what do you say ????
Tat2Matt
Sellersburg Indiana
21 Bronco Badlands Sasquach Lux
I've had the prototype IAG dome lights before production, then we installed the production version on Bill's (Eville Truck). Then we switched mine to the Mabett version.
I really wanted the option to be able to turn the domes on from the factory button so I personally prefer the Mabett because all of my upfitter switches are spoken for.
I was overall very happy with both because of the amount of light that was provided, but I have had a few issues with the Mabett staying on. When it happens, it seems they time out and then go back to functioning normally.
The Mabett is an easier install and I do like the look of the smoked lens, but when they shut off they do not fade down like the IAG.
I personally think they are both very good options especially for the lack of light from the factory. I still have the iag production lights still in the box sitting in my garage.
I will link the install videos for both.
helifino16
Ron
Mount Sinai, NY (Long Island)
I did the IAG version and while the Tap was hard to install, I haven't had any issue at all since. They will always come on with the doors open (have not tried removing the doors), so it would have been nice to be able to switch that off. They both look to be sourced from similar suppliers, but IAG backs their stuff pretty well. It's really up to you - kind of a toss-up.
BigSkyBronco
Big Sky Country
'06 Wrangler Rubicon Unlimited - '96 Toyota FZJ80
+1 for the IAG domes, they are bright. The wiring was a bit tricky but I enjoy working on my truck so that just made the install more interesting. Mine come on with the doors and with a dedicated up fitter switch (6). No regrets at all!
EilersPark
Hans
Leander, Tx
2012 Dodge Ram 1500 4x4
I have the Mabett side and rear dome setup. Easy install, but do have the occasional issue where they don’t shut off for several minutes.
StrainedCMOS
StrainedCMOS
Vancouver, BC
2023 Ford Bronco
It would seem if you want to control the lights with the dome switch, Mabett is the only option, but Mabett seems to have QC issues possibly on the initial batches of their lights.
BroncoA512021
Long Island, NY
www.facebook.com
2021 Ford Bronco OBX
I do... they are made in the same chinese factory
Razorback
Dallas
Lincoln MKX
Another for Mabett. I would buy them again even with the light on issue. It happens occasionally and when it does, they go off after about a mile of driving. Not really sure why the side lights would stay on occasionally when rear dome has gone out.
Strizzo
Houston, Tx
Lexus GX460, 1966 Mustang Convertible, Jeep Wrangler TJ
I have the mabett, and they do have a delay sometimes turning off but only once did they just not shut off but a stop/start cycle fixed it. I ordered the iag before and didn’t install once I saw how involved it was. Been meaning to list them here.
Ninjak
Miami
Oh, I understand they are made in China, and probably by the same manufacturer as you state, but the Mabbet is the easier install, and I for one do not like screwing with electrical as it is not my strong suit.
