mabett bronco interior lite kit
2023bronco
location
vehicles
Sorry they are out of stock now. Probably available at end of November.
@Mabett is there an update or version 2 to the 4-piece interior lights? I've read about the issues with needing to set the instrument brightness to 100% and the lights getting confused in different outdoor lighting.
22Wildtrak
2022 Ford Bronco
@Mabett is on here, perhaps they can provide some info directly.
I have them in my bronco now they started out working good then they would stay stuck on and then would not turn off so I had to disconnect them
mhtucker78
Matthew
VA
2023 OBX Bronco
Starting to happen to mine now.
Mabett
Mabett
China
www.facebook.com
Bronco Black Diamond
The newly arrived batch will not have this issue.
starliner
bob
churubusco, indiana
96bronco,99superduty,explorer,lincoln mkx,33for
when will the new batch arrive? thanks for response
2023bronco
location
vehicles
Can I return my uninstalled set (purchased in May) for exchange? Or can you send the new harness to correct this?
Cletus
Washington
23 Heritage, 92 Mustang GT vert, 67 Mustang coupe
The 4pc set purchased/installed in September only occasionally works, regardless of dimmer setting. How can I get a new set from the November batch?
Mabett
Mabett
China
www.facebook.com
Any problems of the interior lights don't work properly, you can record a video and send me and I will offer help.
GroovyGeek
Boyan
'23 Bronco BD
I hear the Mabett ones are better for installation but not sure if that’s factual.
A blind guy with two left hands who has never handled a wrench can install the Mabett lights in 15 mins. No splicing of near impossible to find wires. No running harnesses up and down the frame. Trivial panel removal. Yes, occasionally it is possessed by gremlins but they clear themselves in under 60s. There are rumors that a v2 is coming, maybe this is why they are OOS.
Mabett will do right by those with problems. Just DM him with a video.
StrainedCMOS
Vancouver, BC
2023 Ford Bronco
I saw there was a restock of the lights on amazon.ca from what looks like a reseller. Would this be the updated version and is the cost really $230 CAD?
tzelko
Tom
Birmingham, Alabama
Bronco Wildtrak
@Mabett
I just installed the LED interior light and having the same issues. won't turn on when you open the door but will if I turn on the interior light switch??
Mabett
Mabett
China
www.facebook.com
@Mabett
Just record a video and PM me.
Coralhead
Floyds Knobs, IN
'23 Bronco Base Squatch
I just installed my Lights yesterday (Nov Batch). Install went well but the actual operation is not as expected. Lights will operate with the door fob lock/unlock as expected. Lights turn off after engine start. Lights will turn on with the dome light switch. Lights will turn on after 10 second delay upon opening the doors. If the vehicle is not locked and getting in the lights will come on after 10 second delay then operated as expected. The 10 sec delay is a no-go for me. (dash lights set at brightest setting) ??????? Any insight?
tzelko
Tom
Birmingham, Alabama
Bronco Wildtrak
Well, the issue was happening immediately after I installed them, however, after i waited for a few hours it started working great. One time when I tried to turned on the interior lights it took about 10 seconds to turn on but only one time, everything works as expected now! The light that it gives off is fantastic and i absolutely love it. Hope it continues to work as it suppose to.
br23
Ben
Madsion, AL
I am having the same issue as above. Open the door and the Mabett lights do not come on. (has sit for over 12 hours).
Then upon depressing the overhead button, they do come on.
Ordered on Amazon and delivered on Nov 28.
What to do??
One would think that the issue could be the rubber/plastic rectangular piece that is close to the plugs and part of the Mabett wiring. Any thoughts??
