I cracked my hard top panel *HELP*
GToddC5
Todd
South Jersey
www.bronco6g.com
Damn, sorry man. It's basically unforgiveable how fragile they designed this top and panels to be.
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
Dang, sorry to hear. I wake up in the middle of the night with nightmares like this. I’d be trying to get a new one from Ford parts (if available).
Beach_Bum
St. Augustine, FL
2023 Outerbanks Bronco
Being that it will be out of pocket and not a warranty claim, you may as well trying "patching" it first. It will likely look like shit and be temporary. But it is worth the shot. The damage looks like a clean crack. You might try JBWeld and then some touch-up paint.
MnLakeBum
MN and FL
‘18 Range Rover Diesel
A good body shop can repair it.
Beach_Bum
St. Augustine, FL
Get some THIN (slightly runny) clear epoxy and let it wick into the crack. Then within one to two minutes wipe off the excess with a clean, smooth cotton cloth. Use some denatured alcohol (Home Depot or Lowes in the paint department) and use another piece of clean cotton cloth and wipe off the surface to clean the epoxy smear with it. Do Not use acetone or you will melt the plastic.
Here is an article on how to thin epoxy using various methods.
Thinning Epoxy – How to Thin Epoxy Resin Correctly?
Cheap Tip: Try the one titled "Denatured Alcohol for Thinning Epoxy Resin" since you are going to need to purchase Denatured Alcohol already.
These were comments made by @North7 last year for a similarly cracked panel. Seems like solid advice.
KidBroSweets
KidBroSweets
Tim
Ford Bronco Badlands
KidBroSweets
KidBroSweets
Tim
In other news after breaking the MIC. I took her off roading for the first time. Made me forget about the whole thing at least for the time being. Still easing my way into the off road world but stumbled upon this track near my house.
RHeinz
Ric
Houston, TX
Fragile design???? With all due respect, what would you have expected? If it was aluminum and dropped on “pavement” would the results have been any different?
I don’t think anyone who has posted here has declared “Fragile Design” when they have dropped their doors on the pavement. Why do you think the top different?
MayhemMike
Mercury
Repair and a wrap of the top will most likely cost less then a new panel.
lakesinai
Charleston SC
Just dropped it putting it back on, heart breaking. Any ideas on how to patch this puppy?
passenger panel on top right corner
If you'd search my post from Oct 2021, you'll see I broke the other corner similarly. There is no honeycomb under there, its solid glass and composite. Its quite strong, but if you drop it just right on the corner, it will snap. The best approach is to repair by injection from below, but you cannot make it much thicker or you'll mess up the gasket. Only way to repair from top is an unsightly build-up. I mixed carbon powder with west system. If you take a few photos from below, and with a slight bend I can see. Or message me.
Funny thing is, some well-positioned tape will stabilize it. Heres the general idea.
1. Separate void, clean and stabilize
2. Fill w thickened epoxy & maybe fiber
3. Clamp to keep contour.
4. Use plastic release material, cover areas to prevent bleed. Cure. Sand/file
5. Cover and shape with carbon & Epoxy.
6. Release plastic. Repeat 5.
Wet sand. Spray with a UV protectant ckear coat. UV rays destroy Epoxy, and the carbon is a close color and a UV blocking agent.
7. You may be able to repair yours from below, avoiding rebuilding the corner as I did. Because it is a thermoplastic material, polyester resin will not work, hence epoxy.
Thats my experience. Its held up 16 months
Ford Bronco I cracked my hard top panel *HELP* SmartSelect_20230218_202949_Gallery
Ford Bronco I cracked my hard top panel *HELP* SmartSelect_20230218_202743_Gallery
Ford Bronco I cracked my hard top panel *HELP* SmartSelect_20230218_202856_Gallery
Ford Bronco I cracked my hard top panel *HELP* SmartSelect_20230218_203029_Gallery
Ford Bronco I cracked my hard top panel *HELP* SmartSelect_20230218_203109_Gallery
