Humming noise after offroading
Broncontonio
Antoine
Calgary, AB
2023 Ford Bronco
I took my Bronco Black Diamond 2.3L offroading a few times since I purchased it 2 months ago. Last time I went really hard on the trail and bashed some plates. Mostly scratches, nothing dented or broke. One of the obstacles was a 28 degree climb on very loose gravel with narly rocks peppering the ascend. It did a big number on my General Grabbers, some areas have tread litterally ripped out.
I've since been noticing a very low hum/very faint grind at speeds over 10mph. No noise when idling or going very low speed. Noise doesn't significanltl increase when accelerated and is only audible when windows are completely rolled up. When windows are down the road noise completely drowns it out.
What could this be?
I'm thinking of replacing the tires and hoping the noise would go away but worried I might have damaged bearings/suspension parts...
Bronco Don
Don
Rialto, California
Tacoma 4x4
It’s the tires, when you lose pieces of your tread, it opens up the lugs, which causes the tired act like a mud terrain, which are very noisy
RC Bronco
Kansas
Holy cow! I’ve abused my Grabbers pretty good but that’s definitely a step up
Might consider taking a video of the noise and sharing it here for more help - I just did this very thing 🙂
5GENIDN
Idaho
thx 5GeNIDN, uploaded a picture, what do you think?
Yea those tires look a bit worse for wear.... I would suggest those would sing pretty loud. Probably the sound you are hearing. I have seen a worse but those are pretty bad.
the poacher
john
Whistler
2010 ford ranger
You might want to speak with the shop that supplied you the tires, for two reasons:
1 - they may be able to help you with the cause of the noise
2 - they may be able to help you with the price on a new set of tires. Those Grabbers are supposed to be a tough, hard wearing tire. I am positive that they have some sort of a warranty, and maybe, you can get them replaced, maybe...
1st 75th ranger
jeffrey
nj
What could this be?
yep tires i had chips and a specific speeds it would chatter back lol
