How to remove overhead console?
TheGriffin1313
Mongo
2022 Mav
Trying to install Homelink mirror with auto dim.
Mongo needs access dang it.
I tried gently with a plastic pry tool and got the front lip of the 6 aux switch but the resistance was not something I felt comfortable to exceed.
Only other option was a vid of adding the 6 aux harness and that involves way more then I need.
i wonder is there a tap point somewhere up here and how to get to it. What if one of those led’s need replacement how does one get to them?
Ford Bronco How to remove overhead console? 88490D04-AACE-4200-BFE4-95820EA0E176
Mlarv
TN
Which mirror did you get to do this?
I watched the video and noticed there is a wiring harness behind the black cover on the windshield that is way easier to get to. You would need to figure out which wire is hot.
TheGriffin1313
TheGriffin1313
Mongo
2022 Mav
I have this one that I also have on the Maverick. Will check out the link.
Ford Bronco How to remove overhead console? 581A1327-D27A-4C21-B6BA-9F2094CA61B9
helifino16
Ron
Mount Sinai, NY (Long Island)
Check YouTube for @1Five1 Garage - they have at least one video (among dozens) that show how that can be removed.
El Bronco Blanco
Scottsdale, AZ
2013 Ford Explorer XLT, 2021 Mazda CX-9
Got a link for the mirror itself OP?
TheGriffin1313
TheGriffin1313
Mongo
2022 Mav
last year Kia motors was selling these at 26 dollars as an error in their system(normally 200+).
All online orders where rejected. Same for toyota and Lexus _Subaru as well use the same ones
So I walked into the parts center at my local KIA store they had only 2 instock both of them since they were so cheap. I have one for the Maverick and the second one for bronco.
link to the Mav forum on how I found out about it.
https://www.mavericktruckclub.com/forum/threads/cheap-auto-dimming-homelink-mirror.8346/
TheGriffin1313
TheGriffin1313
Mongo
2022 Mav
I did see this post
https://www.bronco6g.com/forum/threads/use-power-from-the-front-windshield-panel.61561/
Its a good starting point for me to see it this can be done. with out ripping the entire upper console out.
I have the mirror in the lab today and I am going to measure its current draw and make sure the wire I tap into can handle the extra draw.
In the mav you need to tap into the light power or the moon roof motor power line.
If you tap into the camera module you will get an camera error code so I don't want to have that happen here.
it draws 160 mA at 12v and 170 mA at 13.5v
So as long as i choose wisely I should be good.
Ford Bronco How to remove overhead console? 02F9B6F6-B576-4B63-9077-6A05B8B8878E
Mlarv
TN
I did see this post
Wow looks like a real electronics shop. ESD mat on desktop real connectors for wire harnesses, a lot newer equipment than I used to work with (think 1980's/90's). This at home or work?
TheGriffin1313
TheGriffin1313
Mongo
2022 Mav
Its the lab at work LOL mine at home would look atrocious
jrod5k
The garage
2023 Bronco Base
Were you able to get this to work? I’m looking at doing the same project. Already have the rear view mirror just trying to figure out the best way to run/tap power
I did see this post
TheGriffin1313
TheGriffin1313
Mongo
2022 Mav
Nope. I just ran wires up and around the windshield and plastic molding to run power for the homelink and “critter cam” display module.
Its discreet enough for me.
Ford Bronco How to remove overhead console? 1686533796280
Ford Bronco How to remove overhead console? 1686533840728
Ford Bronco How to remove overhead console? 1686533863410
