How is everyone running the winch wiring?
TLO
Canada
youtube.com
2 door
More specifically, are you doing anything to protect the bumper and lower grill trim from chaffing ...
I have mine between the bumper and trim and pushed back as far as possible, but I feel it can be better.
Pics welcome!
Ford Bronco How is everyone running the winch wiring? 2294
Freebird32
Harold
97 F150 4x4, 82 Toyota 4x4 orig owner, 08 Z06
I ran mine behind winch it doesn’t touch the trim. Tie wrapped
Ford Bronco How is everyone running the winch wiring? 1774877896799-ic
The Green Flash
The Sierra
2022 Outer Banks
Mako
Gregg
Houston Tx
2023 Bronco Badland Sasquatch
Pics welcome!
Mostly with patience and scratched knuckles....
TLO
TLO
Canada
youtube.com
2 door
NC_Oak
2024 4 door 2.3 sasq
I didn't use 1", I don't recall what I used but it fit tight. I also ran mine up along the front cornerbefore the wheel well. IT's pretty obvious area to use and runs right up along the battery
NorthShoreBronco
Steph
Canada
www.youtube.com
21 Badlands 2D, 22 BD 4 Door
Here's where not to run it.... I didn't realize two of my winch mount bolts didn't engage the nuts in the back plate, they were tight , but just because they were jamed in between the plate, not in the actuall nut.... first try to pull a car stuck in ice and this happened.
Had the wiring up behind the grill and shutters... guess who no longer has working shutters and a cracked grill....
TLO
TLO
Canada
youtube.com
2 door
Damn!
I broke my grill and shutters on my then new 2021 as well... Going across an icy stream 😔
TLO
TLO
Canada
youtube.com
2 door
So basically way over behind the headlight?
Routed mine under the tray and in through the intercooler window
Can’t see it at all from the front - usually it’s all tucked under the cover, just pulled it out so you can see the routing. Doesn’t touch any painted trim
Ford Bronco How is everyone running the winch wiring? imag
  • Like
Reactions: TLO
