Charles Miller
Charles
San Jose, Ca
Soon Bronco 2021
I have a 2023 Ford Bronco Badland Sasquatch.
Installed:
37” Mickey Thompson Baja Boss AT
Icon fully adjustable 2.5 shocks
FMI uppers
Core 4x4 track bar
Heavy-duty steering rack and tie rods
Current measurement:
(ground to edge of fender)
Front 42”
Rear 43”
Obviously, 1 inch is due to the tires. There are a lot of posts about axle angles, shock, comparisons, and so forth. It all includes saying that extreme angles cause heavier wear, which I accept. My question is for people with setups near mine, what are your measurements and how long have you run at that height with no issues?
Ford Bronco How HIGH is ok? IMG_0611
Ford Bronco How HIGH is ok? IMG_0579
Ford Bronco How HIGH is ok? IMG_0610
Oldhippie
Barry
Santa Cruz, Calif.
I am also at 42”/43”…been running there for about 12k miles without issue but I also added a diff drop for some piece of mind…nice setup!
Charles Miller
Charles Miller
Charles
San Jose, Ca
Soon Bronco 2021
My RCI skid plates would need to be cut for a diff drop. Which brand are you using? Plus using a diff drop defeats the extra inch I get with my tires
Baja Bronco
2Sun AZ
22 Ford Bronco, 20 Ford Raptor
ICON Stage 8 System, sitting at 43 F, 44 R. Rear has ICON’s heavy duty springs, when I lode the truck for a run, rear squats an inch to be 43 at all 4. Roughly 15K miles, 13K of them in Baja, no issues.
Charles Miller
Charles Miller
Charles
San Jose, Ca
Soon Bronco 2021
Well, that’s definitely an inch higher than I am, and am I right you have 37s too? Did you do any other upgrades, steering?
Baja Bronco
2Sun AZ
Yep, 37 Toyo RTs. Haven’t upgraded the steering box yet, but I did install Foutz full tie rods. They’ve been on for all the miles.
Charles Miller
Charles Miller
Charles
San Jose, Ca
Soon Bronco 2021
I had Icon tie-rods, but one of them started leaking. So now I'm using the HD rods from my new rack.
KABQ
Aaron
Albuquerque, NM
Baja Bronco
2Sun AZ
The Foutz rods were expensive. $1K, but just about every Foutz product is over engineered, and over built. You don’t have to worry about their stuff. I thought that they were the best out there.
helifino16
Ron
Mount Sinai, NY (Long Island)
I believe the Byrds set it at “Eight Miles High”
Oldhippie
Barry
Santa Cruz, Calif.
i would be very careful at full droop with Icon (or stock King) coilovers without a diff drop…their extended length is more than recommended for CV extension…ya only lose the clearance at the diff itself (still not as bad as a solid axle) and modifying the skid isn’t much of a job…I have stock skids…party on!
Charles Miller
Charles Miller
Charles
San Jose, Ca
Soon Bronco 2021
What is the brand of diff drop you have?
