How do yo store your portable compressor?
userdude
Jared
Denton, TX
2023 2dr Badsquatch
Nice! I have had no problems with the Morrflate four-way system. I do recommend getting the dust covers for the hoses and their rubber slip on valve stem caps. Sounds like a silly thing but it really speeds up the process and makes it a lot easier.
What are those two things you're talking about? I looked at their accessories and I don't see what you're talking about.
userdude
Jared
Denton, TX
2023 2dr Badsquatch
I was just using the cheap bag that came with my trickflate…now it is mounted under the hood on a Marz mount…
How hard was that to mount? Did you need to relocate anything?
GI_Jo_Nathan
Jonathan
userdude
Jared
Denton, TX
2023 2dr Badsquatch
GI_Jo_Nathan
Jonathan
Does that make it easier to remove the chuck? That's probably my biggest complaint, sometimes I feel like I'm going to rip the stem out... lol 😱
Yes and no. For me the chucks tend to go straight into the dirt as soon as you set them down which makes things more difficult. So the cleaner they are the better they work. What I found works the best for me is to always use two hands and press the base of the chuck in towards the valve stem while manipulating the collar with your other hand. It makes it move a little easier.
Rydfree
Benny
Alabama
Now I just need to find a nice hose system.....maybe a two-way or a 4 way? Does anybody have experience with one that is good?
Don't need to over think an air hose. Probably get crap from being a tightwad but I use this setup from Amazon. It works great and coils up easily to fit nicely in the same bag the Morrflate 10SixPro came in. The quick connects are quality and no leaks from the times I have used it. The hose tubing is easily cut to exact length with a knife if you prefer and pop right back in to the fittings. I have several spare fittings thrown in the bag as well if I ever need a repair. The only mod I made to it was to add a Tee fitting ahead of the ball valve so I could use the included schrader valve to let air out or to check pressure with my own gauge.
Ford Bronco How do yo store your portable compressor? 4way hose
Amazon.com: YIYADECO 4 Way Tire Inflation System with Closed Flow Chuck for Car Trucks Off Road Vehicles-Compatible with HPA Tanks and Compressors : Automotive
Oldhippie
Barry
Santa Cruz, Calif.
Not bad…a computer box is moved to the side of the mount (very simple)…good video on the website…
