How did Goodyear get this contract
broncosor
2022 Bronco Badlands
Am I the only one who like the Goodyear?
After 9000 miles of all conditions of dry wet, snow, offroad, they have performed well in all conditions.
They are by far the lightest ATs on the market at 10lbs lighter per tire than a KO2 and 20lbs per tire lighter than a Toyo or Nitto. That’s a 100lbs saving in total vehicle weight.
The other day when road tripping I measured the Bronco weight at a truck station and I was 20lbs below the max GVWR. If I had heavy tires I would have been way higher than that, not to mention poor acceleration and mpg due to the high rotating weight.
Ducksworth
Dan
21 Rubicon, 22 Badlands
I'm with you on this, I don't get all the hate for the Goodyears. I've done some moderate offroad trails with a mix of mud, dirt, sand, etc. and they have performed quite well.
Dillhole
Andy
Van down by the river
2012 Jeep Wrangler 2dr
I have no experience with these specific tires but there does seem to be a strong anti-goodyear bias on this forum for some unknown reason.
AKBronc49
Russ
Anchorage, Alaska
I'm not a Goodyear tire fan, don't have them on any of my other vehicles. But I have to say I'm pretty happy with my Sasquatch tires at 7k miles. Now I don't run them in the winter, I have dedicated studded snow tires for that. But the goodyears are wearing evenly and have plenty of traction in the rain.
BostonSasquatch
Randy
Boston
Bronco Lux Badlands with hardtop and Sasquatch
does this explain why PPF isn't available on the sasquatch 2.7L!
You can always do it yourself! (Or have it done. Lots of posts on this and the other site.)
Sixtysixpride
Zach
Mi
Ranger
I have no problem avoiding mud. Like I said it wasn’t intentional just using Fords Raptor test site to have some fun.
Classic28
Brandon
Maryland
Nissan Titan
Inquiring minds want to know more about these rear ac vents in development.
Lcubed
l
UsA
VW golf r, 2023 ManBadSquatch
i'm thinking that ford and 3M couldn't agree on how much to thin out the PPF for application onto the Sasquatchs in bulk.
Krimzun
TX
JEEP/JEEP
That weight savings comes at a cost of durability. If your a moderate off roader you will see the reports of the lighter tires chunking apart on the trails/rocks. Thinner side walls, smaller lugs that are rock magnets, and a tire that isn’t true to size they are closer to a 33’s. While weight is important, function os the main reason behind heavier tires like Toyo,Nitto, being so popular. With my personal preference the KM3 and Gladiator MTs. They are tanks by comparison.
ejaffe
New Jersey
Audi TT
I have no problem with the Goodyears considering they need to be everything to everyone. For a vehicle that is on pavement way more than anywhere else, these tires are quiet and work great in dry and wet conditions. It would be pretty cool if a manufacturer offered Mickey Thompsons as an option though!
broncosor
They are not closer to a 33.
They are 34.4" in diameter (which in my books is much closer to 35 than 33), whereas the KO2 in the same size is 34.3". Having compared both side by side the Goodyear is also slightly wider.
Of course, being 100 lbs lighter for a set of 5 compared to other models you sacrifice some durability. But not much in reality. Plus I don’t mind changing the tires a little more often, considering the advantages it brings.
But to each his own. Some people put 75 lbs 37" tires then complain about mpg, acceleration and breaking tie roads.
I am really happy with the Goodyear for a mix of City, highway, snow, low speed rock driving and high speed off-roading :)
Razorbak86
Northwest Arkansas
Ford Bronco, BMW R1150 GS
Krimzun
TX
JEEP/JEEP
They might be 34.4 on paper but they aren’t that under load which is how most people talk about off road tires. A quick search shows they are normally 33.7 under load on multiple forums making them closer to 33.
kodiakisland
Arkansas
Very few people measure a tire under load since that is too variable due to weight, rim width, PSI, etc. Everyone knows it is smaller once mounted and no one refers to a 33 inch tire as the true height on a vehicle.
