How big can I go with a Base Model?
RR Bronco
Maryland
4Dr Rapid Red Bronco, 83 CJ7, Highlander
I've read so many conflicting posts, I just want to make sure what I'm looking at will fit on a base four door. I don't want to remove anything or add a lift at this time.
I'm looking at 17 x 8.5 wheel +35 offset with a 285/70/17 tire. I don't want any or very minimal poke. Will this work without rubbing? What's the biggest setup I could do?
Let's see some pictures and set ups of base models without any other changes other than wheels and tires.
Will_05
Toyota
Yes those 33ā€ tires will work with no additional modifications needed, so long as you have the +35mm offset. I don’t have any pics but there are tons on ā€œPage 1, Post 1ā€ of this sub forum. You can also Google keywords ā€œbronco 33ā€ +35 offsetā€ for additional info/photos.
Sincerely,
Base Bronco Reservation Holder who has completed dozens of hours of research on the subjectšŸ˜†
BroncoAZ
Mitch
This is definite:
285/75R16 will fit your stock steel wheels
285/70R17 will fit any stock 17" wheels at +55 with no poke
285/70R17 will fit without mods at +30 but will poke slightly (1/5" of tread)
From what I've seen others do:
285/75R17 will fit stock 17" wheels at +55 with no poke
35x10.5R17 will fit 17" +35mm wheels with no real poke, sidewall, not tread
RR Bronco
RR Bronco
Maryland
Sincerely,
That's what I thought, but one of the vendors from this site that I'm working with didn't think it would fit, so I wanted to be sure before I ordered.
Good luck with your reservation.
adamm13
Adam
Holly Springs, NC
ā€˜21 Bronco Big Bend
I ran 285/70/17s on my stock big bend rims for a minute. Zero rub, crash bars in place.
Then I went to 35s :)
Ford Bronco How big can I go with a Base Model? 7B2D6B5E-5248-4F6F-9071-F32296818E34
Will_05
Toyota
Thanks! My ETA is 3/16!
After extensive research, I have decided to go with 285/70/17 KO2’s on +18mm wheels. This will give me the amount of poke that I am looking for. It will also allow me to stick with the stock suspension while leaving the crash bars in place without tire rub. I also worry about how well my 2.3L engine with 3.73 gearing would pull 35’s.
I had a tough time finding someone with an offset other than 0mm to +35 so here is a video that I found of a Base model with 33’s on 17ā€ +18mm offset wheels:
Mzekew
Nissan Xterra
I have same tire size on Sasquatch wheels - fits great. Wouldn’t go any larger due to gearing and transmission.
Ford Bronco How big can I go with a Base Model? 115DB9D8-62A6-4A2E-9DC6-F2DEC54628B9
RR Bronco
RR Bronco
Maryland
This is definite:
Great info! thanks
Rocky88
Lee
Rocky@1970
Ford F150
This is definite:
[/QUOTE Here are pictures on my non sas Badlands with 295/70r17 on Method 703 + 35mm offset…Poke is minimal…
Ford Bronco How big can I go with a Base Model? A5D1064C-9793-4292-91F6-6855FF544C7A
Ford Bronco How big can I go with a Base Model? 32A1012B-609D-4089-A3F9-C4CD509D1E58
