HOSS 1.0 base suspension, shock failure. Not the recalled set..
Dan00Hawk
Plainfield, IL
2023 Bronco
Anyone with leaking shocks during the warranty period have them denied due to aftermarket wheels and tires? My 285 tires weigh more than the 255 OEM Big Bend tires but the wheels weigh the same. Overall about 10 lbs more per tire.
I'm debating the time and effort of putting my OEM wheels and tires back on for the dealer service visit just to ensure it's covered by warranty.
2023 Big Bend, 30k miles, non Sasquatch. With all factory HOSS 1.0 suspension, not lifted. Not the recalled version. Passenger rear shock is dripping.
Ford Bronco HOSS 1.0 base suspension, shock failure. Not the recalled set.. IMG_20250703_163557979_HDR
Ford Bronco HOSS 1.0 base suspension, shock failure. Not the recalled set.. IMG_20250703_163621953_HDR
Ford Bronco HOSS 1.0 base suspension, shock failure. Not the recalled set.. IMG_20250703_163645768_HDR
Sgt Badlands
Midwesr
I would put the originals back on. They are looking for any reason to deny. Not even sure warranty covers shocks and struts.
Beach_Bum
St. Augustine, FL
2023 Outerbanks Bronco
Put the original wheels/tires back on for the service visit. You are still within your 3yr/36k factory warranty. If they don't replace them, consider it an opportunity to upgrade.
Dan00Hawk
Dan00Hawk
Plainfield, IL
2023 Bronco
Thanks for the feedback. Heading in with the OEM wheels to eliminate that from being a concern.
Mike leggiero
Ky
you got your money worth out of them thats it. i have 2 broncos with the same shocks with 37s one has 29000 miles other 9000 miles . shocks are a wear item so no warrenty .
I’m sure there’s no end to takeoffs for
Hitachis around here for dirt cheap. If you were local I have a set you could just have, along with a beer to drink while you load them, to get out of my garage.
My wife did get a shock replaced under warranty on her Bronco Sport, it had started leaking at 12k miles. So while it is a wear item, it can still be warrantied for defects
Dan00Hawk
Dan00Hawk
Plainfield, IL
2023 Bronco
Dealer just called me. As it is leaking and not just worn, the dealer deems it a failure that is covered by warranty. So a new one will arrive in a few days, installed and paid for by Ford. I suppose I needed to rotate my tires anyway and get some use outta these bland Big Bend wheels. 🤣
Update: Fixed by dealer with no issues.
Ford Bronco HOSS 1.0 base suspension, shock failure. Not the recalled set.. IMG_20250705_131513962_HDR
