- Doug
- Jun 23, 2024
- 33
- 1,542
- 3,611
- Washington
- '24 4-dr WT, '22 2-dr WT, '15 Explorer Sport, '02 F250 SD V-10
- Wildtrak
We've had a 2dr WT for over a year and just bought a 2024 4dr WT. The 2dr had some squeaks in the roof and I had used Sil-Glyde lube purchased off Amazon on several seals. It helped quiet some of the noise. Well, the new 4dr had quickly developed a HORRENDOUS squeak somewhere in the back. A friend with a '22 4dr WT correctly identified the source as being the seal on the rear glass that is against the tail gate. After verification of the source, I cleaned the seal with 99% IPA and applied sparingly with a very, very thin layer of Sil-Glyde seal lube, working it into the sealing surfaces. The squeak was gleefully ELIMINATED! I went down to my buddies place, and did the same on his '22 WT. Worked like a charm on his, too. He was shocked I so quickly eliminated that squeak that has been driving him crazy for over 2-1/2 years. Give it a shot. Note that it is a thick silicone grease. You don't want to get this stuff on any surfaces PRE-PAINT or you will have paint adhesion problems as it is extremely difficult to remove. Don't use too much, either or it will collect dust, dog hair, and ever other particle that gets close. Not sure how long an application will last, but it's easy to apply and a single tube could probably treat 1/2 of the 6g Broncos ever built.
https://a.co/d/19Jhyi6
