hood rack?
brkdncr
Southern California
Toyota 86
Is there such thing as a rack that goes across the front of the hood? maybe to mount a slim rotopax liquid canister or recovery equipment? Seems like those front mounts are underutilized.
@Mabett here’s an idea if you’re looking for new items to sell to Bronco suckers.
cr117
PNW
Bronco, EV6
That would make it pretty difficult to open your hood…
X-Rack
Nick
Bethpage, NY
2022 Ford Bronco
Do you Fish?
Ford Bronco hood rack? IMG_0179
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
Those mounting points do seem under utilized 🤔
I’d like to see some AUX light pod attachments on those trail sights.
brkdncr
brkdncr
Southern California
Toyota 86
I rarely open my hood, and wing nuts or some other simple disconnect would make good access simple. It’s not like you would be putting a lot of stuff on it.
MNBigfoot
MN
Are you talking about on top of the thin aluminum hood, or strictly to the tiedowns?
JohnnyBronco
Pennsylania
X4
Never stopped Land Rover from mounting the spare tire up front. I presume tge dipstick was accessible without having to remove the tire every morning before starting the motor. Yes, 60-70 years ago not only was it standard practice to check oil daily but service stations would check for you every fillup.
5GENIDN
Idaho
I have a hard enough time seeing the trail directly in front of my tires that I already have to use a camera.... ;) ... Not sure I would want to diminish what I already have too little of.
I did add the dune flag mount and I get the fishing pole mounts.... But rotopax or a spare?????
The trail sights do make good tiedowns for any long items on a roof rack though or for the limb risers.
DriveAllNight
Dan
N.J.
24 Wildtrak, 25 Audi Q6 etron Quattro
With a steel hood and heavy duty spring lifts , sure you could mount stuff on the hood - however neither of those are the case.
X-Rack
Nick
Bethpage, NY
2022 Ford Bronco
Attached to the trail sites which have a 150lb rating as per Ford.
