MFP2241
WV
2 Door Antimatter Blue BaseSquatch
Decided to add some ditch lights to the Bronco. My original plan was to mount a pair of KC Rally 400's directly to the accessory mounting points in front of the A-pillars. Unfortunately, on the passenger side, the light ended up interfering with the antenna.
I started looking at some of the aftermarket ditch-light brackets, but decided to make my own for a few reasons.
First, I just couldn't justify spending $70–$90 for a couple of brackets. Sick of the Bronco Tax.
Second, I wasn't really crazy about the look of most of the ones I found. Most seem to mount to the two factory holes, then step up an inch or so with the mounting hardware underneath. Just my personal preference, but I thought they looked a little unfinished. And any time you have something sticking up into the airflow, it seems like another opportunity for wind noise or whistling.
Third, at the end of the day, I just enjoy making my own stuff and being able to design it exactly the way I want it to look.
So I came up with this quick design. I went to my local metal supplier and bought a piece of 1" wide x 3/8" thick aluminum flat bar. I bought 8" of material, it ended up costing me just over $8 out the door.
After cutting the ends to the shape I wanted, I split most of the width of the bar on the bandsaw, then cleaned up everything with some files and a Dremel. I drilled the two mounting holes and tapped a 3/8" hole for the light. I used some stainless hardware I already had laying around.
The end result is pretty much exactly what I was looking for: simple and clean, with no unnecessary hardware or brackets sticking up into the airflow.
The lights still retain full adjustability both up and down and left to right, so I didn't give up any functionality compared with a conventional bracket.
For now, I just painted the brackets. At some point I'll probably pull them off powder coat them, but for now the paint will do.
All in all, this was probably about a half-day project, and for roughly $8 in material, I think it was well worth the time. Just wanted to share in case anyone else is considering ditch lights and likes the idea of making their own brackets.
Ford Bronco Homemade $8 Ditch Light Brackets DIY 20260829_160257
Ford Bronco Homemade $8 Ditch Light Brackets DIY 20260830_124017
Ford Bronco Homemade $8 Ditch Light Brackets DIY 20260830_124147
Ford Bronco Homemade $8 Ditch Light Brackets DIY 20260830_124002
HalfmuleFarmer
Thomas
2025 Badlands
Black screws, c’mon!
23OBX2.7
AB Canada
2023 Bronco
Very nice!
MFP2241
MFP2241
WV
The screws holding the brackets down are the stock Bronco Bolts. I really only changed the light mounting bolts because the black 3/8" bolts that came from KC were NF, since I was threading aluminum I went with NC's.
CitrusBronco
Everglades
Citrus county, FL
Everglades
Great job, now when is the group buy going to be available. I’d love some $8 mounts 🤣
I was gonna ask - now that the OP has made a set, considering the labor that went into it, what would the retail price be?
CitrusBronco
Everglades
Citrus county, FL
Everglades
Whatever the market will bear is always the correct answer.
I’ve given some thought to making a set myself, even run through a few ideas based on scrap I have on hand. As of now I don’t need them and it’s hot out, so they can wait.
AZ4x4Adventure
Jason
Phoenix
64 Impala, 22 Explorer, 23 Big Bend SAS 2.7
Those are very nice.
I would like to see a countersunk screw for attaching just to make a little cleaner looking than having the 2 heads sticking up.
MFP2241
MFP2241
WV
I was going to do that, but the material thickness at the Bronco bolts is just over 1/8"... countersinking them was going to make it a little too thin.
If you want them flush, a nice SS allenhead CSK is probably the way to go.
MFP2241
MFP2241
WV
Honestly, with the right equipment, to cut, mill, drill and tap, someone could knock out a bunch of sets pretty quick. The milling attachment on my South Bend 9B lathe just wasn't up to the task unfortunately.
But ultimately though, my "labor" consisted of time in the garage, cold beer, listening to '80 hair metal, and getting to mess with my Bronco... so, time we'll spent 🙂.
Steve_In_29
St Johns, Arizona
2024 Heritage Limited, 2 Door, 1973 Bronco, 1999 Ranger, 2007 F350
Threaded directly into aluminum is a bad idea. The vibrations will cause the steel bolt to abrade the aluminum threads
Perhaps look into a longer light mounting bolt and add a jam nut on bottom.
