Highway light switch
Onestepmore
Amos
Ballwin, MO
2023 Ford Bronco Badlands with Sasquatch
Ok...I'm not the sharpest tool in the shed but this Highway light switch is making me crazy!!! I'll pull it sometimes and it works Great...I pull it other times and it won't go on so I have to hold it so I can see the crazy deer running around trying to get hit by my 23 Bronco Badlands Sasquatch!!! On top of that...whose idea was it to make the owners manual digital??? Any thoughts are Greatly appreciated!!!...Amos
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
What's a "highway light?" High beams?
If so, do you have auto high beams turned on? I'm wondering if it's turning them on/off when you're trying to do the opposite. If so, try turning them off and see if that helps.
Ninjak
Miami
Highway light switch? You mean the brights ?
Onestepmore
Onestepmore
Amos
Ballwin, MO
Yep...they used to be called highway lights...but high beams is the correct description...sorry
Onestepmore
Onestepmore
Amos
Ballwin, MO
I'll give it a whirl...yep...High beams is a more contemporary description...Thanks for the suggestion
604Bronco
British Columbia
www.bronco6g.com
This might be helpful as well:
helifino16
Ron
Mount Sinai, NY (Long Island)
I think I know what's going on. He has the light switch in 'Auto' mode (the default). When you push the stalk forward, you would assume that the high beams would come on. If this is illuminated in the dash:
Ford Bronco Highway light switch 1709308282006
Then they will only come on when there is no car coming towards you or in front of you (tail lights detected). To disable this, either switch the headlight switch to 'D' (on)
Ford Bronco Highway light switch 1709308384502
or push/pull the stalk once to temporarily disable the auto-mode. This will cycle on/off with subsequent pushes of the stalk.
In the 'Headlamps On' mode ('D') the high beams will illuminate regardless of any other vehicle in view with any push of the stalk.
Onestepmore
Onestepmore
Amos
Ballwin, MO
I think I know what's going on. He has the light switch in 'Auto' mode (the default). When you push the stalk forward, you would assume that the high beams would come on. If this is illuminated:
In the 'On' mode the high beams will illuminate regardless or any other vehicle in view.
Thanks for the help...I'll give it a whirl and see if this works
SoDak1623
Cole
South Dakota
1996 F150, 2022 Badlands MT
In my driving experience, this works if you want the auto system off. Using the stalk to actuate the high beams should disable the auto system until you enable it again.
