Hero Switches
MrBud
MN
2011 F150, 2021 Bronco
BrentC
Brent
Calgary, AB
2019 F150 Sport, 2021 Bronco Badlands
Machine Gun Fury
Carl
Southeastern USA
2021 Ford Bronco Outerbanks
My Wildtrak hero switch bank has the empty space where the sta-bar disconnect button would be on a First Edition or a Badlands. Has anyone swapped out their stock hero switches with the one that comes stock on the FE or the Badlands? I'm just curious to see if the functionality of the buttons would be the same minus the sta-bar disconnect button.
To answer your question as I have done this in my Wildtrak, it does work with no errors. Stabar Disco button is lit up but does nothing when you press it as Wildtrak does not come with this feature as you know and should expect. All of the other buttons work perfect with no problems.
Wirenut20
Wirenut20
2020 Explorer ST, 97 F150, 92 Mustang LX 5.0
Thank you very much for letting me know.
NatureBoy
Virginia Beach
2022 Base Bronco
Could you be more specific about your situation? Looking to do the same. Did you simply order the part from your dealer? If so, did they install, how much was it?
Machine Gun Fury
Carl
Southeastern USA
I just popped the original one out with a plastic pry tool, unplugged it, plugged in the new one, and snapped it back into place. I got it from Ruxer Ford, best place to get parts and you can get in on the forum discount since you are a member here and Phil @flip has outstanding customer service. Hit him up to get a quote, can't go wrong with them. I will post some pictures when I get home.
mcinfantry
Lee
Louisiana
Badlands 2 door
Tex
Cliff
San Angelo
I wonder if you could wire up an unrelated accessory to the dead switch, like maybe a winch relay or something. Though, that being said, I've found that little space to be really useful and I'm not sure I want to give it up.
Bronco cat
Carl
Morgantown wv
‘20 Explorer ST, ‘19 GT350, ‘21 Bronco Sport
Sooner
Ted
Henryetta, Ok
69 F100, 56 CJ5, 11 F250, 17 F150
I have found that a Copenhagen can fits perfectly on my Base Mansquatch.
braften
st louis mo
2022 Bronco. goodbye accord, you served well
Wait you have sta-bar disconnect but no trail turn????
Manual badlands come in this configuration, trail turn is auto trans only
