Hero Switches
Wirenut20
2020 Explorer ST, 97 F150, 92 Mustang LX 5.0
My Wildtrak hero switch bank has the empty space where the sta-bar disconnect button would be on a First Edition or a Badlands. Has anyone swapped out their stock hero switches with the one that comes stock on the FE or the Badlands? I'm just curious to see if the functionality of the buttons would be the same minus the sta-bar disconnect button.
Raptor911
Raptor911
Broadlands, VA
what? not sure I understand. You want to swap out the switches BUT The sway bar disconnect would not do anything as the wildtrak does not have the hardware.
I don't get it.
Wirenut20
Wirenut20
I don't get it.
Yes. I'm not a fan of the empty space where the sta-bar disconnect button would be.
BrentC
Brent
Calgary, AB
2019 F150 Sport, 2021 Bronco Badlands
You can have fun with the empty space…
Ford Bronco Hero Switches 2A342F96-AE4B-42C8-AFBF-440EE15D3BB4
drew707
Ford Explorer
I mean technically it would be plug and play and drop in. The hero switches are referred to as SIMA (Switch Input Module A). Since it just has basically power and CAN I would imagine that there won’t be any errors or issues. It can’t enable something that doesn’t exist but it itself doesn’t define what exists. Might be able to get the SBD to light up which would be a fun trick
HarderCorer
Ohio
Wrangler, Bronco Sport
I'll be missing a few buttons (MT BD) so I'm hoping the missing space seems more planned/useful. I like BrentC's use of space. I've already started eyeballing different things. Just have to see...
JohnnyBronco
Pennsylania
X4
I would like to swap out for a full bank of switches and then be able to use the new ones for Aux switches.
That is a reasonable idea although "switches" may only be "switch" as in singular. I didn't know the space was for a switch, thought maybe (but dies not fit) meant for keyfob and my complaint is its too small for my ez-pass which I move between vehicles
GToddC5
Todd
South Jersey
www.bronco6g.com
SubmarineNuke
Richard
Houston, TX
twitch.tv
Bronco Wildtrak
DDGator
Duane
Tampa, FL
2022 Bronco Big Bend 4-door Soft Top
My Big Bend is missing 3 switches and it makes the perfect place for my garage door opener remote! Always and up side! ;)
MrBud
MN
2011 F150, 2021 Bronco
BrentC
Brent
Calgary, AB
