Help with wheel offset choice?
Broncointhesmokies
Seth
Catogl56!@
2022 bronco
Is anyone running 17 x 8 wheels with 0 mm offset that wouldn’t mind sharing pictures of the amount of poke from base fender flares?
BOLD Renegade93
Bossier City, LA
2021 Ford Bronco Black Diamond
Ford Bronco Help with wheel offset choice? DF58C181-87B5-4EBC-9645-AA62659BF35F
Ford Bronco Help with wheel offset choice? 4C2B1135-C622-49AC-8C71-33E83F5A5B81
So I know you said you wanted pics of non-SAS flares, but these are my 17x8 with 0 offset wheels paired with SAS flares. Just cut the flares in half and hopefully that helps you envision it with regular flares
BOLD Renegade93
Bossier City, LA
I lied! I found some older ones before swapping the non-SAS flares to SAS in my cloud storage. Different angle but it shows a good difference in tread coverage.
Ford Bronco Help with wheel offset choice? 3B6D3BD2-92AC-4F89-936E-732BE1A02598
Ford Bronco Help with wheel offset choice? 1D22A372-7DC5-4E10-846E-AB19A62DD778
BOLD Renegade93
Bossier City, LA
My tires are 295s so a little more tread width than others you typically see.
HoosierDaddy
__ Eric
NW. Indiana
OK, I'll play "Let's post exactly what you're NOT looking for"!!
LOL
Method 703
17 x 8.5 +35mm offset
35 x 11.5 - 17 Load Range C
Standard flares
base Base - NO LIFT!!! No rub
Ford Bronco Help with wheel offset choice? 1643604535747
Ford Bronco Help with wheel offset choice? 1643604598364
Ford Bronco Help with wheel offset choice? 1643604624539
Ford Bronco Help with wheel offset choice? 1643604749926
TXAG96
Tyler, Texas
'20 Bullitt, '01 Boxster, '87 TBird Turbo Coupe
LOL
Method 703
Standard flares
nicely done
BOLD Renegade93
Bossier City, LA
LOL
Method 703
Standard flares
Hey I corrected myself after doing some digging! Now they can see both options in case they desire to swap flares. Above and beyond!
HoosierDaddy
__ Eric
NW. Indiana
Like we need a strong reason to post up our mods..... LOL!!!!
Them ...."Hey, who has Fifeteen52's and 33's? Post em up!!!!"
US.... " Umm yeah, check out dees Methods and 35's!!!!"
BOLD Renegade93
Bossier City, LA
Nope. Humble brag all day!
Broncointhesmokies
Seth
Catogl56!@
2022 bronco
Thank you so much and I really appreciate it!!! I may end up having to put sas flares as you have. Awesome look!
donivan
Houston
Mercedes GL63
Tire width will be the main driver for amount of poke assuming 0 mm wheel. You will not see as many 17x8 0 mm wheels as 17x8.5 0 mm wheels on this site. Poke will essentially be the same between those two wheels widths with 0 mm offset because the poke is driven by the tire width since the wheel is narrower than the tire.
Broncointhesmokies
Seth
Catogl56!@
2022 bronco
Thanks man - I appreciate the reply!
Broncointhesmokies
Seth
Catogl56!@
2022 bronco
LOL
Method 703
Standard flares
Hah - I do appreciate the reply. I’ve seen your bronco several times and love it. I’ve actually taken a screenshot of your bronco as comparison guide Because I love the way yours looks!
MattBoogaard
ND
Newbe here so not sure if this is best place to post this. I have NON SAS Flares and looking to trade for SAS flares. Seems like there are many people wanting to both directions.
