HELP - Rear Parking Sensor(s) Connector
Mustang Mike
Toronto Ontario
Mustang GT
I recently removed my rear bumper unplugging my sensor harness (just inside where the rear wheel well meets the bumper) and now while reinstalling the bumper, I’m experiencing an issue getting the wire harness to plug back into the sensor harness?
I’m used to these kind of connectors having an audible “click” when fully seated? There is no click, and the male end appears to not be firmly or securely plugged in?
I obviously I don’t want to force anything so figured I’d ask if anyone has had experience in this area?
TIA
Cobrafang
Thomas
GA
I changed mine out and somehow plugged the license plate light into a sensor. Anyways the connectors do seat in…..even if you use the wrong one🤦🏻
Skanderbeg
Everglades
Rav4
Everglades
TIA
I'm having the same issue. Did you ever find a fix for it?
Mustang Mike
Mustang Mike
Toronto Ontario
Mustang GT
Yah I used zip ties to make sure they wouldn’t pull apart! lol
I also used a little dielectric grease inside the socket for good measure just in the event the seal was no longer doing it’s job?
Skanderbeg
Everglades
Rav4
Everglades
Did you also get a faulty parking aid error?
Mustang Mike
Mustang Mike
Toronto Ontario
Mustang GT
Deleted User 5719102
Who's
On a Lake
22 2dr
The rear parking sensors aren’t working on the screen it’s giving me that error. Idk maybe I broke something
I just replaced my front and rear bumpers this week and I too am getting parking aid fault msg when I shift into rev.
Skanderbeg
Everglades
Rav4
Everglades
Were you able to click in the wiring harness for the parking sensors? Mine doesn’t click in so I assume they’re not getting power so it’s giving me that error.
Who's
On a Lake
22 2dr
Yes all four sensors clicked in and the input pigtail behind the p/s fender. I've rechecked 3-4 times on all.
Skanderbeg
Everglades
Rav4
Everglades
Seems like we have the same issue but for different reasons.
Mustang Mike
Mustang Mike
Toronto Ontario
Mustang GT
In my case it appeared to just be the plug not seating properly, I think it gave an indication initially but was straight dangling there unplugged? Once I was able to zip tie through no codes came up and I didn’t have to “rest” anything?
Skanderbeg
Everglades
Rav4
Everglades
Mine is in, still gives me that code.
RDNK
Doug
Oregon
2017 F150
I just changed out my rear bumber and the orange rubber seal inside the connector deformed when I attempted to plug it in casuing it not to fully seat. I carefully cleaned up both sides of the connector and applied dielectric grease and the plugs snapped in and everything works.
Kvnhorton
Kevin
2023 Bronco
I am having the same issue. Unplugged and couldn’t plug back in completely. When you say cleaned up both sides, did you pull the whole harness or just clear any debris and reinsert with grease?
