Help Please: Caliper Bolt loose / damaged caliper base?
retrospex
Jay
FL
'23 Wildtrak, Audi RS5 B8.5
Hey guys, not sure how to approach this, any help would be much appreciated. I have my Wildtrak in the shop right now getting perch collars installed. The shop messaged me the following:
Ford Bronco Help Please: Caliper Bolt loose / damaged caliper base? shop message
Ford Bronco Help Please: Caliper Bolt loose / damaged caliper base? WhatsApp Image 2023-09-20 at 9.40.09 AM (2)
Ford Bronco Help Please: Caliper Bolt loose / damaged caliper base? WhatsApp Image 2023-09-20 at 9.40.08 AM
Ford Bronco Help Please: Caliper Bolt loose / damaged caliper base? WhatsApp Image 2023-09-20 at 9.40.09 AM (1)
Current modifications:
BFG KO2s 37"
Method 305: 17 x 8.5, 0 offset
The wheels and tires were installed two weeks ago. I picked up the vehicle less than two months ago, there are currently 745 miles on the vehicle. I am unsure how to proceed with this. I do have the bumper to bumper warranty. Thank you all for any input.
Edit: The driver front side is the area in question
(edit: removed duplicate image)
PWillette
Parrie
Maine
Certainly looks like a miss at the factory. Considering your mods I'm guessing your dealer is going to deny warranty but worth a shot. $170 fix isn't a bad hit, I'd probably just bite the bullet out of pocket.
flip
Phil
IN
www.ruxerparts.com
Fords
So who took the bolt out is the question. Option 1, the bolt was never installed correctly when it left the factory and the selling dealer didn't notice it. Option 2, wheel and tire installer took it out for whatever reason and didn't reinstall it correctly. Option 3, you did it and not fessing up (kidding).
Based on the amount of rust where the bolt shoulder should be, my guess would be option 1 or option 1.5 which the bolt was not completely backed out when the dealer did the PDI and did so over the course of you driving it.
Did they say if there was any factory loc-tite on the bolt? Either way, I'd have them throw a new bolt in the support and ask them to check torque on the others. Surprised the tire shop didn't see it when they did their thing.
retrospex
retrospex
Jay
FL
I was considering this also, save myself from the down time.
*edit: I think $170 is just parts, I hope it's including everything.
retrospex
retrospex
Jay
FL
Thank you very much for your input. The wheels and tires were installed at Discount Tire, and done right in front of me. They didn't touch any other bolts from what I saw unless something slipped my sight while I was staring at my new wheels.
I will ask the shop to throw a new bolt in there, hopefully it's something easily done. I will ask about the loc-tite. Do you think the "damaged caliper base" will allow a new bolt? Reaching out to them now.
flip
Phil
IN
www.ruxerparts.com
Fords
If a new bolt goes in and torques down, let 'er eat.
Bikeric
Tulsa
2022 Badlands LUX on 37's
If I found something like that on my vehicle I would first try and torque the screws back down. Not my rig though.
retrospex
retrospex
Jay
FL
I received this in response:
"The problem is not the bolt, since when assembling the bolt they placed it on its side and inside the thread at the base of the caliper is damaged, that is why the screw does not fit anymore."
retrospex
retrospex
Jay
FL
I hoped this would be possible, but from the last response it doesn't seem like it.
flip
Phil
IN
www.ruxerparts.com
Fords
What the hell does that even mean? If that's the case it was a factory defect and should be covered.
Bikeric
Tulsa
It sounds like your bolt threads might have been damaged, which is understandable.
retrospex
retrospex
Jay
FL
Lol the guy responding is not fluent in English (this is common in Miami, I'm still getting used to it). I would hope this gets fixed under my warranty I paid for, just hope they don't give me any nonsense with my mods.
flip
Phil
IN
www.ruxerparts.com
Fords
The dealer doing the work, is it the same one you bought the bronco from?
retrospex
retrospex
Jay
FL
Yeah he mentioned something about that, I just hope it's safe for me to drive for a few days until I get a service appointment. I do have a second vehicle I can use if it's bad bad.
retrospex
retrospex
Jay
FL
Unfortunately I am a good distance from that dealer, it would be a different one. I got it from Tampa, I'm currently in MIA.
