Help needed - New enclosure for OEM CHMSL light
CamptownBD
Milwaukee
Bronco Raptor
Hey everyone — sorry for the random post, but I’ve been trying to find a clean way to relocate the factory CHMSL to improve rear visibility. I know there are plenty of spare tire-mounted light options out there, but I haven’t found anything that’s essentially a direct OEM relocation/replacement.
My goal is to relocate the factory light module from the stock stalk mount to the spare tire mount using one of the existing spare lug mounting options.
Here’s where I could use some help, because I think others might appreciate a setup like this as well:
I’ve already taken apart the CHMSL stalk and looked at how the light module is wired and mounted internally, so I know that the lgith module itself can be removed from the stalk (not one peice). Would anyone with 3D printing or CAD experience be interested in designing a housing/enclosure for the factory light module that would:
  • Protect the OEM light assembly
  • Mount securely to the spare tire
  • Retain the factory wiring and functionality
The idea is to avoid splicing wires, using aftermarket lights, or losing OEM functionality — simply relocating the factory light lower and out of the rear line of sight.
If anyone knows of an existing enclosure or solution that already does this, I’d love to hear about it.
Thanks for taking the time to read this.
Deadpool392
New Bern, NC
2025 Marsh Gray Bronco Raptor, 2020 Gator JTR (retired)
Turn Offroad’s chase light has a nice bracket. The light is … meh, but nice bracket. Not sure if it has plug and play harness or requires splicing though
CamptownBD
Milwaukee
Bronco Raptor
Probably not exactly what you’re looking for, but here is an option that appears to be able to be returned to stock easily.
https://www.4x4truckleds.com/diode-dynamics-ss10-chase-light-reverse-light-kit-for-2021-ford-bronco/
I bought a rigid chase light and spliced the wiring myself to get it moved, if I want to return to stock I’ll just splice the original wiring back.
Thanks for the response. I have been keeping an eye on this one, too. It looks like they have the wiring harness and it's plug and play, but doesn't have the three dot wide light. I know I may not "need" it, but using whats already there would be great. Maybe I'm being too picky.
Deadpool392
New Bern, NC
Nothing wrong with wanting what you want, I have not seen anything like that available though. I have not seen all of the different lighting modes on the SS10, they might have something close though. Good luck, hope you find what you want.
