Help with Swapping fog lights
Braptorx
Alex
Dubai
2023 Bronco Raptor, 2020 F150 Raptor
Hi, I'm swapping the factory fog lights for the Morimoto big banger kit, they have sent me a triple wiring harness, 6 connectors in total, with one upfitter connection, this also has the relays built into it, so all on or off, no individual control, as I have a mix of yellow and white, I would like some sort of selection, also thinking what do I do with the factory fog light switch? Do I leave this unconnected? What I would like is a harness with 3 upftitter terminations and 6 connectors, and the relays built in, now this might not exist, but I have always used relays in the past on the F150 raptor then I'm not tied to which up fitters to use. I'm not going to install this myself, but I would prefer to deliver the installer a finished harness, rather than rely on them here to "make it". any pointers greatly appreciated. Thanks
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Braptorx
Braptorx
Alex
Dubai
Thank you Adam for your assistance. You went above and beyond to sort this for me. Will post back once I have got it all sorted. One thing I didn't check was the amperage on the factory fog light. With the morimoto pulling at 3.2 (I think) do you think it will be OK. Not sure what the oem ones are?
4x4TruckLEDs.com
Adam
Lindenhurst, NY
It should be fine.
